Holepuncher
Holepuncher, if you compare the red and green lines relevant respectively to NiMH and alkaline batteries in the MesserForum runtime test you can clearly see how much less stressed the LED is with the latter. It has more or less clearly been stated by LL designers that they count on that difference to ensure a long life to the LED itself.
I see what you mean. There is about a 20% difference in stress. As I mentioned in one of my earlier posts I measured about 700 ma for both NiMH and Alkaline and thats what I based my comment on. The "0" point of the red and green lines in the curves confirm my measurement. It looks like there is a 15% or so drop in the first 5 minutes for both the red and green. With proper heat sinking the Cree is rated for 1000mA. This light may not have proper heatsinking but there is a decent chunk of metal under the led - probably enough to handle 600mA or so continuously. We are not talking about over stressing here. On turbo that may be entirely different. A quick measurement I did yesterday showed 1200mA with fresh alkalines on turbo so even with alkalines the light can be over stressed.
