Hi all,
I just purchased the LED Lenser X21.
I thought I might pop a review for you guys to drool over (i know i do).
The manufactures blurb:
Postage was 20$ registered and 4$ insurance.
For a torch 573$ is allot of money to spend (luckily the Rudd government paid for mine =D with the 900$ economy stimulus package)
Performance
This torch has a excellent performance, outstrips a 4 D-Cell maglite many fold.
I took it outside recently and I reached a visible 200m range at night (confirmed by Google earth, im sure it can go further but I have not had a chance to see as of yet)
Build quality
Case is made up from metal aluminum I do believe, it has a solid high quality feel, and much like one of the old maglite's that security guards carry around as a weapon.
Packaging
The torch was well packed. It came in a black plastic case, solid enough construction to protect the torch during normal wear and tear. The hinges for it are plastic so im not sure how long they will last.
Thoughts/Comments/Experiences
This is an excellent torch, I keep it in the boot of the car for those occasions that you need a torch and this exceeds what I was expecting out of this torch.
I can say this torch is pretty drunk proof and
The switch is a 3 state switch (off - low beam - high beam) I do like this function but the switch is extremely sensitive and I have accidentally blinded myself many times.
On my torch I have applied some glow tape to locate the torch in the dark; this can be seen in the pictures as the thick green tape.
In the pictures I have compared the LED Lenser X21 to the LED Lenser Hokus-Focus and the Maglite 2X C cell.
Pictures (apologies on the quality)
Box & Torch
Torch& Paperwork
Torch Comparisons. Left to right, LED Lenser Hokus-Focus, Maglite 2X C cell, LED Lenser X21
My attempt at beam shot on narrow beam (can vaguely see it in the dust)
Shining torch at hand at full brightness.
The following pictures are with the cameras auto adjust ON (no real comparison between beam intensity).
Narrow Beam (Spot)
Wide Beam (Flood)
The following pictures are with the cameras auto adjust OFF (black image included for reference)
Narrow Beam (Spot)
Off
Low
High
Wide Beam (Flood)
Off
Low
High
The following pictures are comparisons between the 3 lights I have
X21 & maglite
X21(Left) & Hokus(Right)
Glow Tape
Charging glow tape on x21
Charged section of glow tape
Full length of glow tape
[FONT="]
[/FONT] Conclusions
Excellent torch, hope you enjoyed my review, please message me if you have any requests, comments, questions and I will do my best to answer them =]
maXim:twothumbs
Over sized images deleted
http://www.candlepowerforums.com/Rules.html#siglines
After shopping around the various stores in my city the recommended retail price was around 699$ and when talking to the shops the best i could get it down to was 650$ in the end i purchased this lil beauty for 549$ AUD off eBay from a seller in Perth (I suspect the price was so cheap because they might import them directly from Germany and are not using the Australian importer ZEN imports).This masterpiece is another milestone in our company history. The LED LENSER® X21 will cause a sensation
because it allows for a whole range of new applications in light engineering. The lamp has a light
output of up to 1068 lumens*. Thanks to the Advanced Focus System, the light cone can be adjusted
dynamically.
You must have held this lamp in your hand to be able to really appreciate it. The LED LENSER® X21 offers
a broad, circular low beam as well as a sharply focused searchlight beam. 7 ultra-bright
high-performance chips and 7 terminator lenses produce a quality of light that you have never
experienced before - a blazing beam that makes even car headlights look pale in comparison. This lamp's
lighting range is already legendary. And its impressive appearance radiates power and authority.
* Average values. May vary +/- 15% depending on type of chip and batteries.
LED 7 x Cree
Length 395 mm
Weight 1488 g
Luminous flux 1068 lm
Batteries 4 x D
Energy tank 120 Wh
Burning life 300 h
Switch Dynamic Switch
| Technical data*
Performance
Build quality
Packaging
Box & Torch
Torch& Paperwork
Narrow Beam (Spot)
Wide Beam (Flood)
Narrow Beam (Spot)
Off
Low
High
Wide Beam (Flood)
Off
Low
High
X21 & maglite
Glow Tape
[FONT="]
[/FONT] Conclusions
maXim:twothumbs
