Looking at the spec sheets of LED's, it's looking a little confusing, as the maximum power is given in amps not watts. If you look at the Seoul spec sheets it lists brightness based on amps in, not overall watts. So is the brightness entirely determined by the amps without consideration for the voltage? (assuming the voltage is within spec).
Say I have an LED that can accept 4v to 5v, and I feed it 1A. Will they be at the same brightness or will the 5v one be identical in brightness? It'd be intuitive to think that the 5v one would be brighter because it has a higher wattage, but the spec sheets don't reflect this, so WTF is going on here.
Another example, say I have the same LED and I give it 1 watt @ 4v x 250ma and an identical one I give 1 watt @ 5v x 200ma, would they be identical in brightness because the wattage is the same, or will the 4v x 250ma LED be brighter because the amperage is higher?
