Zero_Enigma
Ok guys. I just got a bit of data overload reading this thread. http://www.candlepowerforums.com/vb/showthread.php?p=2696020#post2696020
Right now I have someone asking me to build them a 3-6 LED light to place over a small fish tank so they can cheaply cultivate algae I think. Ahh ok I got their message here.
I assume that's 18" x 4". Anyways, I'm familiar with the Cree Q5 and SSC P4 U-bin LED's so I'm thinking of using those for the build but need some help on how to do this.
My skill level is low but I do know how to use a soldering iron. I have soldered fan wire repairs for the computers, my trail riding MTB light and helmet light soldering the DX drivers and wires to a on off switch, and some electronic components for my dad. What I need help from everyone is what plug in the wall (Canada 120v I think) driver can I use to build this?
*--*--*-----[on\off]-----[driver]-----=
It would be nice if there was a high and low mode on the light should the person wanting to keep the light on 24/7 on low mode but later want to move that to another tank but want to bump the lighting up they have a dual use function.
Also I am planning on building a small aquaponic setup myself but not like the aeroponic setup. My setup uses the fish water in the fish tank to grow my indoor veggies. In that thread I think they said you can't get tomatos out of CFL bulbs well I'm using 6500k bulbs and I got my Tiny Tim tomato plant which is growing like mad with a crazy root structure in my hydroponics setup right now. Tho fruit production probably isn't as plenty as if you had some HPS or crazy LED grow lights. I've grown spinish, lettuce, tomatos, with those 6500 bulbs before, The ones that did not work were strawberry. I still have a strawberry runner in the aquaponics system but it did not really grow to well. I'm using 2 x I think (23W or) 32W 6500k bulbs. I'm thinking of making some small aquaponics setup with a 5-10gal tank but considering using LED's for small veg crops as tomatos well I may have to use more lighting for them. My thinking is using 8 x Cree Q5 WC LED's all powered to 1000mA with a plug in wall driver. Can I get some help here on what driver to use and somelinks to help me out? Thanks.
The application I have in mind is to light a refugium, which is effectively a planted area of a marine tank to grow algae in order to export nutrients. I'd like to do LEDs as the length of time that the area will be illuminated would be served nicely by LEDs.
I'd just like to know what you figure it would cost for the materials and your time for the fabrication of a lighting setup for the 18 x 4 space - effectively just a strip of LEDs, which shouldn't be too hard to put thogether. Doesn't have to be pretty either since it's going to be inside of a stand over a sump![]()
