Blindasabat
I finally tried a few LEDs direct drive off a 17670 (4.05V no load) all at once to try to estimate the Vf of a few emitters.
First I measured the current off a known Rebel of D bin (3-3.25V) and got 2.2Amp. Same I measured off my TVOD K2 several times. Good so far.
Then I did it to a K2 F bin. 0.9-1A. I had my highest and lowest brackets. So I thought.
Unknown bin K2 = 1.3Amp. An E bin?
Unknown Rebel = 2.2Amp. D bin.
Then I tried an XP-E Q2-5C. 3Amps solid. Woah! It's only rated for 1A. What bin is that? It must be under 3V. I tried it a couple of times for just a second each. Same reading. For a Q2 flux bin, it should be efficient.
Interesting results if you plan to direct drive any LEDs. I should try a CR123 next.
All LEDs were on stars and only for 2-3 seconds except less for the XP-E at 3A.
