I'm a mechanical by nature trying to design an LED circuit. I'm going to have 22 parallel-series circuits with 7 LEDS in each series.
I'm designing for a 24 constant voltage PS. The amperage is 3.3 A (22 parallel chains each requiring .150 A -> 22*.150 = 3.3 A).
Each LED is nominal 3.2 Vf - so 7*3.2 = 22.4 volts required per series circuit. Each LED requires .150A.
Calculate resistor to place in line:
24 volts input - 22.4 volts required = 1.6 volts to disappate.
V=IR -> 1.6=.150A*R -> R=10.67 ohms.
My question is:
What happens if my LEDS come in with a higher Vf? With only 24 volts supplied - and with some being disappated by the resistor will be there be a possibiliy that a chain will not light? There is a maximum Vf on these chips of 3.6 volts. I ordered these to a specific color temp - but no binning on Vf.
I appreciate your responses. I believe I'm being overly concerned. But I need some assurances before sending this out to a board house.
My question is:
