VanIsleDSM
I bought this 8" bench grinder for grinding tool bits for my mini lathe.
I made the heatsinks for the high power LEDs on my lathe.. 2 left over ebay 3watt LEDs. They differ in colour output so I thought this would be a fine spot for them.. where it won't matter. Power to the original lights from the grinder was 12VAC, I put in a full bridge rectifier with some diodes and drove the LEDs with an LM317 constant current mode, plus a 920uF cap to smooth the out the AC. You can see the LM317 and it's resistor under the heatsink that's mounted on top of the old bulb socket... I did everything so it could be reversible should I need to return the grinder under warranty.
I started a discussion talking about the rectified current through the LEDs with different capacitors and such here:
http://www.candlepowerforums.com/vb/showthread.php?p=2417501#post2417501
Original bulbs were 10watt each.. and were absolutely useless.. they weren't placed out far enough so the wheel just casts a huge shadow over the work area.
The 3watt LEDs could be placed much nearer to the ends of the plastic shrouds.. reducing the shadow a lot.. but there's still some left.. what a bad design, still, much brighter though for a fraction of the power.
I thought about moving the LEDs outside of the shroud to get a better angle to project the light from, but decided not to because I wanted to keep the LEDs in the protected shroud behind the clear plastic.. and a more original look, so I devised some reflectors.
I'm very pleased.. and I can see now! The reflectors are just some thin aluminum with mirrored mylar laminated onto the business side... I may end up painting the backs of them black to match the grinder better.
Well that's it, hope you enjoy the pics, they were taken on manual with the same settings for a consistent comparison.
Now I need to modify the tool support on the left wheel so I can actually change the angle on it.. the original is just stuck where it is.. you can move it in to compensate for wear on the wheel.. but no angle adjustment.. I've just been grinding tools freehand since I got my lathe... I'll do something about this soon.
