the initial question is how to plug 6 ledengin 15w at 1500mA and 15v
assuming you want white. I guess these are in series, as Vf is pretty high.
So, lets say you have the first driver option to work with, and you need to power a total of 9 units? Am I reading you right so far?
Normally with high-power LEDs, it's a good idea not to have LEDs or strings of LEDs paralleled. This is because as they heat up, they draw more current. If one string heats up more than the other that is parallel with it, it draws more current. More current means more heat. More heat means more current. This means the other string starts getting less and less current. Eventually the hotter string will fry from overheating/overdriving.
The bad news: this makes the number of LEDs you can safely drive per driver smaller.
The good news: it's easier to calculate how many LEDs per driver, as they are all to be in series!
Now, if you DO want to try to put two strings paralleled, you will need to make sure that the two strings have the same Vf, same heatsinking. Plus, you will want something to limit current from shifting from one string to the other too much. Usually resistors are used for this, but with the amount of current going through these, your resistor would end up being huge. I'm not really sure of a good way to do this, so perhaps someone else will chime in.
As for running them in one series string, if you ran all 9 LEDs at 1500mA, you would need a driver capable of outputting 135V (9*15V) at 1.5A.
Alternatively, you could get 2 drivers and split them up to lower the total Vf needed.
