Lego lights....??
Ken2step
I have been reading where you guys and gals are legoing the Quark and Fenix lights and did finally see in the 4Sevens list of accessories for the Quark's the body tubes. I have a Quark AA2. Am I correct to think that a Quark 123 body will work with this light? Do you just lego with same voltage type lights? Thought that to have a extra body tube for different batteries might be good for my BugOutBag. Thanks for any advice!
Ken
The Quark lights has two types of heads:
Low voltage that works with 1xAA, 2xAA, 1xCR123 and 1xLiIon
High voltage heads that works with 2xCR123, 2xLiIon and also 1xLiIon with slightly reduced output, at the end of the runtime.
When playing lego you just have to use the correct type of head, the only danger is using the low voltage head on 2xCR123 or 2xLiIon, that will probably fry :poof: the head.
Thanks HKJ!
Looks like fun so I am going to order some to play with and learn. Thanks for the help!
Ken
