Lets see how convincing YOU are?
Youfoundnemo
Munfordville, KY
I have been looking into getting a better EDC for a while now and I believe that I have found what I am looking for, a nitecore D10. now lets just see if some of you have the power to move my will and purchase a different light.
P.S. Who makes pocket clips for the D10 anyways because that will be an important thing when or if get the D10
A pocket clip is being designed and built as we speak for the D10, and will be offered shortly on 4sevens.com
D10 appears to be a good light, no reason to convince you otherwise. I'm also waiting to see the pocket clip for it, well ex10 rather.
Well, some people are putting their own clips on, like the one on the Rayovac 2xAA Highbeam/Sportsman Extreme lights.
The clip which is attached via 3 little screws is the one being designed and built for the D10 and EX10. There are some pictures of it floating around here, most of them prototype images or CAD images.
I don't have that power, but I might suggest you also get yourself a LiteFlux LF5XT. It and the D10 alternate as my EDC's, both are fantastic lights with different approaches to functionality.
I think you have done a great job of properly convincing yourself already.
But, (there's always a "but" :) ), I bought both the D10 and EX10 at the same time so I have used them both at various times.
I also have the LF5XT, so here's my take as one who has them all...
If the AA battery requirement were that important to me (and it sort of is from an availability standpoint), then I'd choose the D10.
However, I find that I now more often grab the EX10 because it's 1/2" shorter than the D10 and seems to be a little brighter than the D10 when using primaries (the D10 is as bright as the EX10 if you use 14500 rechargeables).
What I really like about the EX10 is not only that it's notably shorter than the D10, but it's diameter is about the same as the D10 which is surprising considering that a CR123 is fatter than a AA battery.
You have to set them side by side to see the difference between the two in diameter.
As far as the LF5XT, it's a great light with a very capable UI, but it's another 1/2" longer than even the D10 which makes it a full 1" longer than the EX10. Plus, while it's UI is pretty cool, I find that if I don't use if for a few days that I forget exactly how to program it.
So based on my opinion of these lights for EDC, I vote for:
EX10 first, due to it's small size, simple and intuitive UI.
The D10 second for the same reasons, but it's longer length make it a second choice.
The LF5XE third because of it's (unnecessarily?) long length and it's not-so-intuitive UI.
The reason I can put the EX10 first is because I typically keep around 50+ CR123's in my battery stash, and replenish as I use them up, so I'm not worried about running out CR123's.
However, when I go on a trip (which I just did to St.Paul, MN), I take the D10 specifically because I know I'll be able to pick up AA's anywhere.
I truly believe from my experience and having owned quite a few EDC type lights, that the EX10 and D10 lights have set a new standard for EDC.
The only light I like better for it's features and it's beam quality is my Novatac 120P, but it's LOT fatter than either Nitecore so I find that while I do grab it quite often, I don't use it quite as much as the EX10 when it's time to make a quick decision when I head out the door.
My .02 and I'm sticking to it...
Oh come on...your better than average! You don`t want to be just another brick in the wall.... Stand out from the crowd!
Every cpf`er and thieir brother has a D10. BORING. Take a chance on something just coming out. Your a special person...you need a special light...400 lumen minimum.
If nothing else...at least get a Surefire UB2 Invictus...something bright
You deserve that and more :thumbsup:
I would rant more...but I`m going outside...play with my D10 :nana:
Interesting. I've been on the fence between the two and while I prefer AA, I have to stock some 123's for my surefires anyway so...
Shorter is good, but a thicker diameter is not so good if it is too much thicker.
What is the diameter difference between the two?
I know there are lots of pictures of the nitecore lights on the forum but does anyone have a side by side shot with only these two lights?
Thanks
Oh because I have seen many in pics on the forum, must be one off things that people have made themselves.
I claim to have bought this via DealExtreme*...and surely it matches the quality of much that comes through that source.
*Three weeks waiting time and worth every penny.
Thanks
The minimal diameter is limited by the size of reflector in this case I think, since both have the same reflector D10 can't be any thinner than EX10.
The D10 is slightly thinner than the EX10, as seen here.
The measurements:
D10: 42.1g, 89.1mm x 20.3mm
EX10: 41.0g, 76.2mm x 21.5mm
Thanks to selfbuilt.
It ultimately comes down to choice of battery, as the size difference is pretty close. I prefer the D10 because I use Eneloop AAs which can be used on my other devices (eg cameras, walkie talkies, remotes etc), and the D10 length is perfect in my hand.
Finally, and very important, you can make your own DIY diffusers from water bottle caps for the D10. The water bottle cap trick is EXCELLENT for making the D10 an even more versatile light.
If small size is your primary criteria for choosing a light, I would recommend the EX10 over the D10. It is minimally larger in diameter than the D10, but is significantly shorter. I also love its stainless steel bezel. For me the EX10 is easier to operate than the D10 with its shorter throw Piston Drive switch. Even without a clip, it fits in any pocket with ease and comfort.
If I were to recommend a slightly longer AA light it would be the LF5XT without question. There is no smoother beam in the AA format and IMO is even superior to the GD PLUS D10 in regard to beam smoothness free of major color artifacts. I actually prefer having a range of 5 preset levels with the LF5xt, rather than the one user defined level that you must adjust repeatedly with the D10 or Ex10. I have my LiteFlux set at 1 %, 15%, 33%, 50%, 75% with a PH giving me 100%. I can select one of these levels faster than ramping a D10/EX10, plus it is much easier on my thumb. Furthermore, it retains my most commonly used last setting of 33% so I don't need to rotate through the other 4 modes unless I want to. While both the D10 and EX10 ramp to the level you need, frequently you lose that setting when you either intentionally or accidentally access Max or Min, something that happens not infrequently for me as my thumb tires. The only disadvantages of the LF5XT over the D10 is the slightly longer learning curve getting up to speed with the light and the longer length of the light, though not SO long that you don't want to carry it.
In summary, I would give the EX10 the heads up as the best small EDC light especially when comparing it to the D10. If size were not the only consideration, I would much rather carry my LF5XT. For all the extras it offers, including its beautiful beam and versatile feature filled interface, the slightly longer LF5XT makes it my EDC first choice most of the time. If you a true flashaholic, own both.
The D10 is thinner. The EX10 has a SS bezel to take up the extra diameter, even though they both use the same reflector.
19mm vs 21.5mm diameter
