Zen|th
Hi guys, I just wanted to know what are the pros and cons about the two? Will one last longer than the other? Will one break faster? Im not too sure about this..
So if u had a choice, which would u choose? Because i am waiting for the release of the P61L. I am planning on buying a G3 Led and install the P61L in.. will the lexan window be able to take the heat?
Heat is usual not a problem with leds, only with high power incan.
I prefer glass/pyrex on my lights, due to the better light transmission and scratch resistance.
So I guess a G3 LED with a lexan window is equipped with a P61L it shouldnt be a problem right?
Not with the front glass, but the heat generated by the led might be a problem for a plastic head (The led might cook itself), your need a G3L with metal head!
Like what Size15's said, the G3L has an aluminium head so it wont be a problem:twothumbs.. right?
Nope.Just to clarify, Lexan = UCL and Pyrex = Borofloat?
Yes, just don't use a old G3L or a G3 as base.
Im sorry but what do you mean by 'old'? I thought G3Ls were new models which were only introduced this year? All equipped with aluminium heads.
If one was to compare the output/runtime chart for a G2L vs 6PL, or a G3L vs 9PL then I believe there would not be that much difference between them. The aluminium bezel makes quite a bit of difference.
So i guess the next light i will be getting is the G3L with the aluminium head with a P61L drop in... (if it ever comes out) :D
