I did a little test for yall:
Cold Tests were performed as follows:
1. Cells charged to ~4.1-4.2V range.
2. 1 of each cell type placed in freezer for ~1 hour or more.
3. SureFire 6P, loaded with a 3.7V LF LED module, and 1 dummy "CR123" cell is placed in a bowl of ice for at least 10 minutes prior to test beginning to chill the flashlight body. (It's aluminum, it immediately starts to melt the ice when placed on it, and immediately gets VERY cold, hehe) CR123 "dummy" cell is loaded at the front, cells to be tested are at the rear, to isolate as much of the heat generated by the LED from the cells being tested.
4. Cell is removed from freezer, open circuit voltage measurement taken, then installed in flashlight, where a tailcap current reading is taken to gage fully charged performance. (this is the "before")
5. Flashlight is turned on, and ran for 15 minutes, flashlight stays on ice throughout the duration of the "run" test". (this is the "after")
6. Cell is retested (open circuit voltage and tailcap current reading).
Warm Testing is basically the same, except without any of the cold :)
Originally, I did a warm test, followed by a cold test, and then decided to repeat the cold test to confirm repeatability and accuracy of the test method. On the first cold tests, the cells were only in the freezer about an hour, on the second testing that I did today, they were in the freezer for about 6 hours prior to testing. Results were about the same.
UF cells are relatively new protected type, they were sent to me for free with a purchase of some AW protected cells in the marketplace a couple months ago, and I haven't really used them, and the person who had them before me didn't use em much either. One of them has a finicky protection circuit, but it did not act up during these tests.
AW RCR123s are his black label protected type, I'v had them for years, they are quite old but still work reasonably well.
IMR16340s are only a few weeks old, probably less than a dozen cycles, I've only "deep" discharged them to ~3V for testing once or twice.
UF RCR123 LiCo warm:
Before: 4.13V, 0.95A
After 3.83V, 0.72A
UF RCR123 LiCo cold:
Before: 4.13V, 0.57A
After: 3.86V, 0.45A
UF: RCR123 LiCo cold
Before: 4.15V 0.57A
After: 3.87V, 0.46A
AW RCR123 LiCo warm:
Before: 4.12V, 0.9A
After: 3.80V, 0.66A
AW RCR123 LiCo cold:
Before: 4.13V, 0.44A
After: 3.86V, 0.40A
Before: 4.17V, 0.42A
After: 3.87V, 0.41A
AW IMR16340 warm:
Before: 4.15V 1.07A
After: 3.78V 0.7A
AW IMR16340 cold:
Before: 4.15V, 0.60A
After: 3.81V, 0.49A
AW IMR16340 cold:
Before: 4.12V 0.54A
After: 3.79V, 0.44A
Semi-Conclusion:
The LiMn cells appear to be much better warm, but seem to take a hit in the cold that knocks em right down to about the performance of a LiCo into this setup. This particular test has shown my hypothesis to be incorrect.
IMO, further testing is required: I have another test in mind that may be more revealing :) I'd like to do a similar test, but with Emoli 18650s vs AW protected LiCo into an incan setup.
More to come later :)
