LiFeP04 vs. LiMN vs. LiNiMnCoO2
snakyjake
WA, USA
These are the three battery chemistries mentioned as safe lithium rechargeables.
I'm wondering if one is more safe than another?
Which can handle over discharging better?
Which is safer for charging?
Which one has more capacity?
Which one is better for the typical high output (100-200 lumen) LED light?
What is the availability of these chemistries in batteries for our lights (RCR123A/18650/etc)?
Thanks,
Jake
Lame, I can't believe no one responded to this in over a year.
Anyhow one to your questions
Lifepo4 is considered the safest of those three. Less likely to spit fire in many conditions
Back to safety again, lifepo4 is the winner here again
Lifepo4
In what regard? Wh/KG, Volumetric, etc?
LiNiMnCoO2 is really the winner of those two anyhow it carries more power in a smaller form factor than the other two.
I'm done, check out battery university for more information, its a great read:
http://batteryuniversity.com/learn/article/explaining_lithium_ion_chemistries
Thanks,
Jake
These are the three battery chemistries mentioned as safe lithium rechargeables. I'm wondering if one is more safe than another?
Safety is relative and difficult to quantify. I would say that LiFePO4 is "safer" only because cells made with that material have significantly lower energy density.
None. The damage that occurs due to over discharge happens at the negative electrode, and all lithium-ion cells use essentially the same negative electrode.
LiFePO4 and LiMn2O4 cannot be overcharged. That is to say that you can certainly charge them to a higher voltage, but you cannot put excess capacity into the cell by doing so. If you charge a cell with the Li(Ni,Co,Mn)O2 cathode to a higher voltage than it is specified for, you will extract excess lithium from the cathode, possibly leading to plating of metallic lithium on the anode and making the cell relatively unstable and unsafe.
In order of increasing capacity and energy: LiFePO4, LiMn2O4, Li(Ni,Co,Mn)O2
Depends on how big you want your battery to be and how much runtime you want. If you are looking for something small that will have a relatively high drain rate on the cell, then the LiMn2O4 is probably best because cells made with that material are usually designed for high discharge rates. If you are looking for something that will have a long runtime, then something with the Li(Ni,Co,Mn)O2 cathode is probably best because cells that use this material are typically designed for high capacity, albeit lower discharge rates. I don't see much use for LiFePO4 cells, except perhaps for certain unregulated hotwire mods where the voltage happens to correspond well to a particular bulb.
They are all pretty much widely available, although if you are looking for Li(Ni,Co,Mn)O2 cells you may have trouble finding anything other than 18650s. Check out the selection from AW.
Cheers,
BG
One reason I stick pretty much exclusively to LiFePO4 among the major lithium chemistries, besides its inherent safety, is the total life cycle cost. LiFePO4 can last for literally thousands of cycles, compared to a few hundred for the other lithium chemistries. Besides a much higher number of cycles, the calender life is much longer. This is actually the bigger selling point for me than the huge number of cycles. One thing which turned me off regarding the other lithium chemistries is the fact that they degrade within a few years whether they're used or not. This to me is unacceptable. I expect any cell I buy to be useable a decade or two later. So far it seems only three types of cells meet that requirement-NiCd, LSD NiMH, and LiFePO4. The jury is still out on LiFePO4, but indications are if not abused they will last well over a decade. The lower energy density is a price I'm willing to pay for longer service life.
High quality cells like those made by A123 can indeed have great cycle life. Low quality LiFePO4 cells, like a lot of the junk available online, can have terrible cycle life.
The "inherent safety" stems from the low energy density. Charge a conventional lithium-ion cell with a LiCoO2 cathode so that it has the same total energy and it will have the same "inherent safety".
This is only true for poor quality cells or cells stored improperly. Good quality cells with LiCoO2 or variants have excellent calendar life. I have tested cells that sat on shelf in my lab for five years and they showed no significant loss in energy or power capability.
Two decades is a long time. I am not sure that LSD NiMH or any lithium-ion cell has been shown to meet those requirements.
Much of the touted advantages of LiFePO4 stem from the lower voltage and lower inherent energy density. For example, a high power A123 18650 has a total energy of 3.5 Wh, compared to an AW IMR high power 18650 which has a total energy of 5.7 Wh. If you charge the AW IMR cell to a lower voltage so that it has the same energy as the A123 cell, you will get most of the same advantages.
I guess that all I am saying is that there are indeed great LiFePO4 cells (e.g. A123) that have the attributes that you find appealing, but there are also garbage LiFePO4 cells. I just don't want others to think that LiFePO4 is synonymous with great cycle life and calendar life.
The other point I want to make is that most of the advantages of LiFePO4 come at a considerable hit on energy density, and most of these advantages can be replicated in traditional lithium-ion cells by simply charging them to a lower voltage.
Food for thought.
Cheers,
BG
No, the inherent safety has nothing at all to do with the lower energy density. Rather, it has to do with the chemistry. In short, runaway exothermic reactions simply cannot occur with this type of battery. And the same characteristics which make the cell more stable chemically also give it longer cycle life. This is why these cells are used in power tools and electric vehicles, both applications where safety and life cycle cost are more important than absolute energy density.
I've little doubt there are junk LiFePO4 cells out there, just as there are junk LiCoO2. Since LiFePO4 isn't commonly used in cheap consumer applications though I would say the market for them is a lot less tolerant of junk, or at least so far I've yet to see any LiFePO4 cells I would call garbage. As with any battery, be aware of what you purchase, and verify manufacturer's claims.
As for calender lifetime, I have NiCd cells over 20 years old which charge just fine. LSD NiMH haven't been around long enough to determine their calender life, but I would think the same mechanisms which prevent self-discharge when stored for years will prevent deterioration. The verdict is still out on LiFePO4 also, but some things I've read suggest a potential calender life of several decades (assuming quality cells, of course).
I'll take your word for this but I've personally yet to see any type of LiCoO2 cell not lose some capacity after even 12 months. This is why I avoid consumer products with built-in Li-Ion batteries like the plague. I figure chances are good in 3 years I'll have an expensive paperweight. Of course, 2 or 3 years is enough for the average person who will have already upgraded to something else before the battery suffers a noticeable capacity loss.
The big problem with your statement here is "This is only true for poor quality cells or cells stored improperly." A person buying a product with Li-Ion cells has no way of knowing if they're getting junk or not, and more importantly if the device is charging/discharging the cells properly. This is why I prefer cells which are somewhat tolerant of abuse, even for my own uses where I'll generally care for them properly. It's a shame LiFePO4 so far has lower energy density than LiCoO2 because to me that's really its only drawback, and the only reason it isn't used more. You may have no use for LiFePO4 personally, but it's very misleading to make a blanket statement like "I don't see much use for LiFePO4 cells, except perhaps for certain unregulated hotwire mods where the voltage happens to correspond well to a particular bulb."
Concerning energy density, the AW IMR26500 tested in the other thread is rated at 2300 mAh, while the K2 Energy LFP26650EV is rated at 3200 mAh. Given that the LFP cell is also rated for 12 A continuous discharge it does not seem to be at much of a disadvantage when compared.
I just purchased 8 of these to power a pair of bike lights. Just to add another data point, the 8 cells test out between 3179 and 3290 mAh at 0.2C ( 660 mA ). They only do about 125 mAh worse at 2C ( 6.6 amps ).
More interesting reading
"A123 replaced the cobalt-oxide-based electrodes of conventional lithium-ion batteries with new nanostructured iron-phosphate electrodes. These phosphates are inherently safer than the cobalt-oxide-based chemistries, which have been known to suddenly burst into flames, destroying laptops and cell phones in the process and leading to massive recalls. The conventional cobalt materials also don't last very long--that's why laptop batteries have to be replaced every couple of years. The capacity of A123's batteries, in contrast, doesn't fade much with use. Safe, long-lasting batteries are essential in cars, where they're expected to survive abusive conditions for a decade or more."
I understand what you are saying, but quite frankly it does have to do with energy density of the full cell, and how much delithiation of the cathode you need to reach that energy. If you charge one of the AW IMR cells 18650 cells to the same energy as an A123 18650, the exothermic reactions you speak of (the ones that liberate oxygen from the cathode) cannot occur either.
With respect to the use of LiFePO4 cells in power tools, the only company that still uses LiFePO4 cells is Black and Decker, and they have been shifting to other cell chemistries because LiFePO4 simply cannot compete for energy and power density.
With respect to EVs, only the Chinese are using LiFePO4 for EVs, and not without significant safety issues. Want to see a demonstration of the "inherent safety" of LiFePO4 in EVs, look here. My point in showing that link is not to say that LiFePO4 is NOT safe, but rather to show that LiFePO4 CAN fail in an unsafe manner. Too many people think that just because they have a LiFePO4 battery that nothing can go wrong.
LiFePO4 has its place in the world of lithium-ion. I think that it makes sense for large, stationary batteries, which is actually the direction that A123 is moving. There is a reason that no commercially available hybrid, plug-in hybrid or EV uses A123 cells...the performance just is not as good as can be achieve with other chemistries.
Possible, but you have to remember that all lithium-ion cells still use the same anode (negative electrode), and a lot of degradation in lithium-ion cells occurs at that electrode as well. LiFePO4 does not do anything to stop degradation mechanisms at the negative electrode that contribute to cycle and calendar life degradation.
Then you have had very, very bad luck my friend.
If you are buying consumer electronics from well known companies, you can be pretty certain that the cells are of reasonable quality and being charged/discharged correctly. However, I must admit that there has been a big push to maximize the capacity of cells for consumer electronics, and often this is done at the detriment of cycle life.
You are right, it is a shame that LiFePO4 doesn't have a higher density. But I stand by my statement for this forum, except perhaps I should have qualified that I was talking about flashlights in particular. I do think that LiFePO4 has a place in the family of lithium-ion, but there are few applications that can utilize its niche advantages.
If I were wrong, A123 Systems would be taking over the world. As it stands, they are struggling to say the least. And they will continue to struggle until they can move beyond LiFePO4.
Cheers,
BG
The point is the exothermic reactions can't occur with a LiFePO4 cell regardless of what you do. That's the definition of inherent safety, and that's the big selling point for me here. You can design in all the protection circuitry you want but fact is sometimes circuits fail. I prefer to use a cell which won't self disassemble if something goes seriously wrong with the protection circuitry.
Honestly, yours is the first statement I've heard, ever, saying that lower energy density is the reason LiFePO4 is safer. This is especially puzzling because there seems to be some overlap in energy density between the IMR cells and LiFePO4, and yet LiFePO4 is still safer. I'd love for a CE to chime in about this because I always thought the sole reason LiFePO4 was safer was the chemistry.
I did a little research. Basically, if you read the article, it seems shoddy workmanship and inattention to detail was the cause of the fire. To quote from the article: "The report adds that the battery cells on the car, made by Zhejiang Wanxiang Group, themselves were not responsible for the accident, but were employed improperly for an electric taxicab."
If anything, this is yet another testament to the inherent safety of LiFePO4. Despite the abuse given to these cells, they failed to explode. Due to the huge current any EV battery puts out a fire can certainly start. But there was no explosion like there might have been if LiCoO2 had been used.
They also make sense for people like me who are looking for a cell they can build into a project, then not think about it for the next decade or more, or worry about it blowing up if something in the charging circuit fails.
As for automotive uses, maybe having to assemble a few thousand 26650 cells into a battery pack is the reason A123's cells aren't being used? If A123 Systems were smart, they would start making larger single cells so that a few dozen could be used for an EV battery pack. Energy density isn't an issue here because "safer" conventional Li-Ion cells, such as the LG Chem cells being used in the Volt, also have lower energy density. To the best of my knowledge nobody is using or planning to use higher energy density LiCoO2 in EVs.
I don't have a good answer for you other than to say that the primary degradation mechanism likely occurs at the cathode. If anode degradation were important, the A123 System cells would suffer regular annual capacity loss, and yet tests show they don't. Maybe anode degradation comes into play over a time span of decades?
Me and everyone else I've known. It's more like you've either had exceptionally good luck, or you've given your cells far better treatment than most people, including myself, ever would. Basically, I expect a rechargeable cell to be ready to use when I want to use it, even if it's been sitting in a drawer for years. That means it either retained a charge, or retained the ability to be charged to near new capacity, perhaps after a few break-in cycles. So far, only NiCd, LSD NiMH, and LiFePO4 have been able to cope with those demands. I've seen all other types of rechargeable lithiums degrade. Same thing with most conventional NiMH.
You hit the nail on the head as to both why LiFePO4 isn't used in consumer electronics, and why also it seems that new devices have worse cycle life than older ones.
Isn't A123 Systems doing research which they claim would eventually increase the energy density of LiFePO4 by something like a factor of four? In any case, A123 Systems signature product is their LiFePO4 cell. IMO they need to focus on improving that, not become yet another player manufacturing the other types of lithium cells. Also, if you ask me, I'd say within a decade chemical cells of all types will be obsolete as ultracapacitors outpace them in both energy and power density.
jtr1962
I simply leave you with this point: if LiFePO4 were all it were cracked up to be then everyone would be using. In fact, the opposite is true. The early adopters (e.g. Black and Decker) are moving away from it, and no major US, Japanese or European car company is using or even considering using it.
If it works for you, then go for it. I stand by my original opinion that LiFePO4 is highly overrated and has only niche applications where it excels.
I also predict that A123 and other LiFePO4 based companies will fail in the next 5 years if one of the following two things does not happen:
1.) they move beyond LiFePO4 (it is not theoretically possible to improve its energy density beyond what it already is)
2.) a new, currently unknown, application is found that is perfect for LiFePO4-based lithium-ion cells
Government funding and investor patience is running out. LiFePO4 was an obsolete chemistry when it was developed (with all due respect to Goodenough and Hydro-Quebec), and it is still an obsolete chemistry.
That being said, my advice and opinions on this forum are free, and are probably worth slightly less than that.
Cheers,
BG
Basically, I had one of two alternatives which met my requirements-four of the 26650 LiFePO4 cells I linked to earlier, or 16 AA Eneloops. The battery pack for my bike headlight needed a capacity of roughly 40 W-hrs, it needed to be inherently safe from explosions, and it needs to last at least ten years with minimal attention. That left me with basically two choices-LSD NiMH or LiFePO4. I'm not aware of anything else which would have met the last two requirements, except maybe NiCd (which would have been too heavy/bulky). Charging 16 AA Eneloops in a series arrangement would have presented unique issues, although I might have gotten away with no balancing due to the good capacity match between cells. LiFePO4 presented less of an issue. Charging circuit is a simple CC/CV setup, and I bought a board to protect against overcharge/overdischarge for $7. I also saved a little weight over using 16 Eneloops. Cost in both cases was about the same, and no more than any of the other types of lithium chemistries. Sure, if I had chosen LiCoO2 I could have used 4 18650s instead of 4 26650s, saved a bit of space and weight. The cost though would have been peace of mind thinking the cells might explode, plus the need to replace the battery pack at least every few years.
I can't imagine I'm the only one who thinks like this. If LiFePO4 currently only has niche uses, then perhaps it's because, like LSD NiMH, not a whole lot of people are even aware of it. I know I wasn't until I joined these forums.
I'll add to your list: 3) An EV using one of the other lithium chemistries explodes.
Lead-acid, carbon-zinc, and even alkaline are 3 battery chemistries which by all rights should be obsolete given that we have superior alternatives, and yet they're still around. Fact is for now LiFePO4 doesn't really have any real competitors in the areas it excels (life cycle cost, safety and power density). Will that change in 5 years? Sure, that's an eternity when it comes to technology. I'm honestly hoping LiFePO4 becomes totally obsolete, along with every other type of chemical battery, in favor of ultracaps.
...it needs to last at least ten years with minimal attention
Isn't that a rather tall order for any cell? I mean, I can understand a ten year shelf life, but ten years with a cell in daily use such as on a bike? I am sure eneloops can't do that, and I'm not sure what can. Almost all cells on the market of any chemistry have a working life of 3-5 years max when in regular use. They wear out and you have to replace them with fresh ones. That's just how it goes.
I've been using the same set of four Eneloops in my current, crappy bike light for three years. They're showing absolutely zero signs of degradation after maybe 250 cycles ( I recharge generally every other ride). Maybe I'll do a break-in cycle soon on my C9000 just to see how their capacity compares to the value I recorded when they were brand new. I've little doubt I could continue to use these same four cells at least until I hit the 1000 cycle mark, at which point they would be in service over a decade. Sorry, but I don't buy into the notion that you should only get 3 to 5 years out of a rechargeable battery, even if the cycle count is low. Old school NiCads regularly lasted at least a decade if not abused. Even lead-acid can last that long if you don't deep discharge it or keep it on float charge. I purposely only buy products which take standard AAAs/AAs, rather than built-in Li-Ion packs, for the simple reason I don't want a paperweight a few years down the road when the battery stops taking a charge, and a new one is either unavailable, or costs almost as much as buying new.
I don't mind if a battery wears out because of cycling, even if it's only a year old. I do mind though if a cell only has 50 cycles, but can't be charged any more when it's only 3 years old because it degraded internally. Bottom line-I favor cells where cycle count is the primary wear mechanism.
Hi jtr1962
I know what the marketing material says, but no lithium-ion cell is inherently safe from explosions. If you get an internal short circuit and flash the electrolyte, the cell is going to vent. And if the vent design or implementation is poor, the cell will overpressurize and explode. I totally understand the issue with exothermic decomposition of the cathode, and that delithiated LiFePO4 is much, much more stable than other lithium-ion cathodes, but the fact remains that you have energy stored in a can with a flammable, volatile electrolyte. Until someone figures out a new electrolyte system, no lithium-ion system is "inherently safe". With the exception of A123 and Valence, most of the LiFePO4 cells I have looked at are pretty poorly constructed and use pretty crappy LiFePO4 material.
I am just saying that you need to be careful and don't put your faith in the idea that LiFePO4 is inherently safe. Very well made LiFePO4 are extremely robost and have great cycle life. But unless you do your due diligence and find those cells, you are likely to get pretty shoddy stuff.
That being said, from a safety perspective, I guess I would rather have a shoddy LiFePO4 cell than a shoddy LiCoO2 cell.
With respect to your cycle life demands, I agree that the lithium-ion cells designed and sold for consumer electronics are pretty poor. But that is not inherent to the chemistry. There are plenty of companies making lithium-ion cells for EVs, plugin hybrids and hybrids that use higher energy density cathode materials and have demonstrated thousands of cycles. There is simply not enough demand for high cycle life lithium-ion cells for consumer electronics. Everyone wants to maximize energy density.
But for your application, given your cycle life requirement and your willingness to use a larger pack, sounds like LiFePO4 is right for you, provided you find good quality cells.
Cheers,
BG
Hi Mr. Happy
Your example comparing the K2 Energy LFP26650EV to the AW IMR 26500 is not quite accurate because the LFP26650EV is an "energy" cell, whereas the AW IMR 26500 is a "power" cell. You would be better off comparing the K2 Energy LFP26650P cell, which is a power cell with a 2600 mAh capacity.
Best to compare apples to apples. For a given cell design that provides a certain C-rate, the energy density of LiFePO4 is approximately 60% of a conventional lithium-ion cell.
A great example can be seen when comparing the A123 18650 with a high power Sanyo 18650. Both are designed for power tools. Take a look at this Ragone plot:
You can see that both have nearly identical C-rate performance, but the A123 cell has ~60% of the total energy of the Sanyo cell.
A good rule of thumb is that it takes three LiFePO4 cells to equal the energy of two conventional lithium-ion cells, all things being equal (i.e. same cell size and form factor, same C-rate, etc...).
Cheers,
BG
Have I mentioned lately how much I enjoy reading the highly intelligent discourse of our members? Holy cow, we have some bright people on this forum!
:party:
That's actually my point. Lately it seems in the interests of greater capacity and/or lower cost, a lot of cells of all chemistries are garbage. The difference is that a garbage LiFePO4 or NiMH cell is far less likely to fail explosively than a garbage LiCoO2 cell.
I came across this which I think you'll find interesting. The relevant part regarding cycle life: "Most other EVs are utilizing new variations on lithium-ion chemistry that sacrifice energy and power density to provide fire resistance, environmental friendliness, very rapid charges (as low as a few minutes), and very long lifespans. These variants (phosphates, titanates, spinels, etc.) have been shown to have a much longer lifetime, with A123 expecting their lithium iron phosphate batteries to last for at least 10+ years and 7000+ charge cycles, and LG Chem expecting their lithium-manganese spinel batteries to last up to 40 years."
It seems regardless of chemistry, there is always the trade off of power density/cycle life versus energy density. I also find it incredible that LG Chem expects a service life of up to 40 years for their cells. Off topic, but I read elsewhere that the greater reliability of EVs versus ICEs might mean a paradigm shift where people actually expect all the major components of their vehicle, including the battery, to last 30 or 40 years with routine maintenance.
I did look at several options, including these. 3 of these cells would have worked instead of 4 of the ones I chose. They even claim 600 cycles to 80% capacity. My main concern though was calender life. I figured I had a better chance of hitting a decade or more of service life with LiFePO4.
I am pretty skeptical of the 40 year prediction for the LG Chem cells as well. Although, I was recently at a conference where independent testing by a national lab showed some extremely impressive data on the LG Chem EV cells, as well as a few cells from other non-LiFePO4 manufacturers. Not sure that I would extrapolate the data 40 years, but I was encouraged that these might realistically last 10 years or so.
Cheers,
BG
