Fulgeo
Hey guyz I purchased 3 of these cells a short while back and wanted to post my results.
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2385
They are well shrink wrapped and measure to spec. The 3 cells measured 3.314v, 3.313v and 3.298v out of the box. After charging them on my e-Station BC6 and resting them a day they measure about 3.50v - 3.58v. The maximum discharge I can perform is 3A with my Triton charger. The first test I performed was a 3A load until 2.5 volts is reached. Here are the end results.
Cell #1 2925 mAh
Cell #2 2930 mAh
Cell #3 2996 mAh
I performed another test with a 3A load until 2.0 volts. The cell delivered 3174 mAh.
Things to note;
After draining down to 2.0 volts the cell bounced back up to 3.03 volts.
The cells under load dropped almost immediately to 2.8 volts then ever so slowly lost voltage till limit. My 26550 A123 cells for comparison drop to 2.85 volts. About the same.
Note that these cells are rated for 7A continuous drain and a 17A burst. In this category they differ from A123 cells. They also differ in that their max charging current is 3.4 amps.
Going to use these cells to drive a 5761 in a 3D Mag build using one of JimmyM's "magic pills" http://www.candlepowerforums.com/vb/showthread.php?t=231489
Happy Mods!
Cell #1 2925 mAh
Cell #2 2930 mAh
Cell #3 2996 mAh
Things to note;
Happy Mods!
