I don't understand the " limited to 1A draw via PTC, but without it they are just the big brother for CR123s cells and can put out stupid amounts™ of current."
is that a good thing? a bad thing? what is a PTC? and more importantly, do they work in a flash light?
Its a safety feature, but neither good nor bad. If you need < 1A of current, its fine. If you need more, its a problem. A PTC is a positive temperature coefficient thermistor. Its a current limiting device, its resistance increases as it gets warm, so if you draw too much current the PTC heats up, increases in resistance, making it heat even more, until it finally goes to a fairly high impedance, and cuts off the current. They are whats used for "self resetting fuses"
Since they have a 2.8v working voltage, then you could probably put 2 in a 2D mag, put a 4D bulb in it, and use that, for something simple, and has a long shelf life. 7.5Ah with a 750mA discharge, so you can pull ~2 watts from one. So you could make a 3D mag that would run a XP-E HEW or XPG at 1A with a switch mode converter (sharkbuck or H6CC) that runs for ~14 hours. 14 hours, with ~250 source lumens with a 80-cri white, or 325 with cool white.
You could probably do 2 in a 2D mag, and with a switching converter that would take 8.4v in for the max, and still runs well with 4.5v in or so, you could make a light like above that runs off of 2x 18650s or 25650s or 2 primary cells. Just have to flip the spring around backwards for the rechargeables and forwards for the primary cells.
And like I said, if you can remove the PTC (dont know how hard that would be) or find a version without, that cell would probably give ~10A without batting an eye, and could probably dump ~50-60A or more when shorted.
