Long Term review: Leatherman Micra.
Monocrom
NYC
Stock photo released to General public:
We all know what it looks like, but reviews are always better with pics. I've carried my Micra as an EDC item for about a year and a half, maybe a bit longer. This is my 2nd Micra. Ironically, I bought it just before becoming horribly addicted to flashlights. The scissors have opened more hard plastic blister packs than I care to recall. These compact scissors are plenty strong enough to cut through the types of blister packs that are popular with flashlight companies. (Wish I could say the same for the scissors on my Victorinox SAK Classic pen-knife). No chipping at all of the Micra's scissors. But there are very slight deformations along the edges. These can probably be removed once the edges are sharpened. That's how slight they are.
I've used the ruler along the handle. Not the sort of thing you want to use if an accurate measurement is critical. But for the average job that doesn't require a longer ruler, the Micra's ruler is just fine.
I've used the non-locking folding tools on the Micra for a variety of purposes. The tweezers are not very useful for most chores. But if you have a hot date, and you notice you also have a slightly long nose-hair.... That's when you'll be glad that your Micra comes with tweezers. Even if they are very small and thin.
I've used the flat Phillips head screwdriver blade as.... well; a screwdriver. Not the sort of thing you want for heavy-duty work, obviously. But for many jobs that require tightening or loosening screws, this will get the job done. Recently, I used this tool for an unintended purpose.... I work as a Security Guard. Part of my job involves patrolling. I have to hit certain, electronic checkpoints with a wand, along my patrol route. The checkpoints are small metal discs. And if they get wet, they don't register on the wand. A couple of weeks ago, the rain turned to ice. The checkpoints were frozen solid! I used my Micra's Phillips head blade to carefully chip away the ice around a few of the checkpoints. It did a great job! Ice chipped away, but checkpoints left undamaged.
The combination small screwdriver / bottle opener is the tool I've used most. (No, I don't drink that much). The bottle opener is barely decent, at best. You have to take a bit of time to make sure that it hooks onto the bottle cap properly. And even then, if you don't go slow; the bottle opener has an annoying tendency to slip off. Found that out while using my Micra to open everyone's bottle of beer at my best friend's fiancee's Birthday party in 2006. Everyone thought I was the Man! ..... Good thing they didn't notice how much I was struggling.
The small screwdriver blade works better than the bottle opener it's attached to. Got a loose sunglass screw? Just reach for your Micra. But I mostly use it as an awl, for making extra holes in my leather belts. Because of a condition I'd rather not discuss, I've been losing weight without really trying. So, my belts often become too wide. The improvised awl on the Micra requires a bit of pushing and twisting. But it makes short work of even quality leather belts. That's why it is the one I use most. Best part is, since it's not a real awl with a sharp point; you can use it while still wearing your pants.
The small knife blade is sharp enough for any reasonable chore that you would expect a pen-blade to perform. I've even used it to sometimes cut down the side of the above-mentioned blister packs. (But mostly, the scissors are enough for that job). The knife blade does seem to dull just a bit too quickly.
The small file seems useful for a bit of grooming.... as in, smoothing out the rough spots after cutting a fingernail down to size. That's about it. The hook portion of the tool (cuticle cleaner?) is tough enough to get the job done. Also comes in handy if your fingernails are too short to create an opening so that you can peel an orange.
The large screwdriver works well. I once used it to pop open a broken locker. Didn't use it to pry open the locker, though. I inserted the Micra's large screwdriver blade into the broken handle, then pulled up until the mechanism inside rode up and caused the locker to open.... Sadly, I can no longer use the tool. I locked myself out of the guard house shed at my current job assignment. The door is not thick or tough at all. Tried to use my Micra to pry the door open. Big mistake, The flimsy door actually bent the large screwdriver blade, just a bit. I stopped, and tried to bend it back the other way. (To make it straight). I thought it was straight, I was wrong. Although it folded back into the tool, it now is hopelessly stuck next to the file blade. No way to seperate the two.
Despite being a useful EDC tool, there are disadvantages. As I said, this is my 2nd Micra. I have encountered the same problems I did with the 1st one. The scissors bind together after awhile. Even one drop of oil seems to be too much. Ironically, if you do nothing, the scissors stop binding up on their own after several more uses. But the scissors don't open or close as quickly as they used to. The tool picks up pocket link and dust to an annoying degree. But even more annoying is the rust that it picks up. I normally wear dress pants, and carry my Micra in my left-front pocket. I don't sweat a lot at all. I also don't pour water down my pants. Yet, both of my Micras had traces of rust (spotting) in several places. While it's mostly surface rust, it does make the tool look cheap and ugly. A mild steel wool should take care of some of the rust spots.... others are a bit more difficult to reach; especially where the handles pivot. A stainless steel tool should not attract rust this easily. If the Micra was a carbon steel folding knife, it would be more understandable.
Rust was also an issue with my Original Leatherman Multi-tool, despite rarely being used or carried.
Conclusion:
A worthwhile tool that attracts dust & rust too easily. Despite that, I can definitely recommend the Micra to anyone needing a tough pair of compact folding scissors, with other handy tools thrown in. I recently purchased a new Micra, along with a Leatherman Micra black sleeve from Lighthound. (Leatherman should include the sleeve with every Micra). It should do an excellent job of reducing the amount of dust & rust that normally gets onto this tool.
Nice, well-balanced review, thanks for posting it. I have a Micra kicking around here somewhere but rarely use it. I always keep going back to the SAK Explorer and opening blister packs with the small knife blade.
I carried a Micra for a year or two, but it has been in my wife's purse for the last 2-3 years. I now carry a Leatherman Squirt-P on my key ring and I find the pliers much more useful than the tiny scissors on the Micra. In general I find the small scissors on any multi-plier tool or SAK next to worthless. A sharp knife blade will work as well or better 99% of the time for me than a tiny pair of scissors.
I EDC a micra as well and have found it very useful. Although it has served me well I am looking for something a little more robust.
.... In general I find the small scissors on any multi-plier tool or SAK next to worthless. A sharp knife blade will work as well or better 99% of the time for me than a tiny pair of scissors.
I can only agree to a certain point. The scissors on my SAK Classic are definitely very light duty only. (Couldn't cut open even one blister pack with them). Other folding scissors on some multi-tools seem only a bit better. But the position of the Micra's scissors makes it tougher than most compact, folding scissors. When the scissors are in the same spot normally reserved for the pliers, the scissors can be made thicker, since there's no need for them to be thin inorder to fold against other tools.
Instead of one thin piece of metal to push down on with your thumb or index finger, you get two actual handles that you can squeeze down on with your hand. More pressure + thicker scissors = More useful than most folding scissors on other multi-tools.
I've had the same LM Micra on my keychain since around 1998. Seldom do I find a daily task the Micra can't handle.
Interesting what one can learn about a poster. Mono is a security guard who lives in an area that sometimes falls below freezing. He has (or at least 2 years ago had) a best friend, doesn't pour water down his pants, can get a hot date and sometimes has a long nose hair. Doesn't drink that much and has pocket lint. Is probably in his 20's because his (current or former) best friend is of marrying age. Doesn't sweat a lot. Can secretly struggle in the presence of others. Has a physical or emotional condition causing unintentional weight loss. I'm guessing irritable bowel syndrome, but we don't need to discuss that here. Digs flashlights and multi-tools, so is in the top percentile of intellect.
And excellent review, btw. :thumbsup:
Right on.
Good, thoughtful review, Monocrom. I have a Micra, which I like, but keep it in my car for emergency use . I also have a Squirt S4 (scissors) and a P4 (pliers), which I somehow seem to keep closer and fool around with more. Frankly, I think I just prefer the looks and the shape of the Squirts---never really done a hard comparison of them vs. the Micra in terms of utility.
Right on.
:crackup:
Thanks for the review monocrom, and for the good laugh powernoodle.
My wife and I have had micra's for many years. On a trip to Reno we discovered a great use for them. We stopped by Boomtown casino on all you can eat lobster night. The scissors on the Micra shelled the lobsters fast and easy. They are very handy little tools.
