FaithinGod
- Joined
- Dec 29, 2004
- Messages
- 132
Dear CPF Members,
Do any of you have any runtime graphs to verify if the runtime for the current Cree and Seoul LED lights have significantly greater runtimes than the current Luxeon III LED lights when driven at low levels of light output (such as when comparing the same flashlight with the Cree LED in it to the same flashlight with the Luxeon III LED in it, or comparing the same flashlight with the Seoul LED in it to the same flashlight with the Luxeon III LED in it, at, for example, 2 to 3 Lumen output)?
I have seen several charts verifying that the Cree and Seoul LED lights do have greater (about double) runtime at maximum levels of light output, but one engineer who I spoke to said he did not believe the low level output of the Cree or Seoul LED lights was significantly longer at the same lower level of light output as the Luxeon LED lights. But I did see a runtime chart on a McGizmo Seoul LED light which was run at a low light output level (about 2-3 Lumen, if I recall) and it ran about 3 days.
My assumption would be that if the output of the Cree and Seoul are twice that of the Luxeon III when at maximum output while also using the same amount of energy, then the low beam output of the Cree or Seoul should also be twice the runtime of the Luxeon III when driven at the same low power level.
If any of you are able to offer help in this regard I would be most grateful.
Thank you sincerely in advance.
FaithinGod
FaithinGod
