ARC mania
Well, heres something a bit different. It bothered me for the longest time about making a multi function module for the EM. Space was a factor so I had to come up with something. So now, the EM is maybe the world's smallest LED flashlight thats 100% regulated with multi functions. I know the LED looks a bit strange but the only way to cram everything into the EM's module, I had no choice but to use this LED which does not require a reflector. It has a 15 degree beam pattern. This is a high powered 3 watt LED and not a 5mm LED. The only light I had to do comparasions with was an Extreme III in high which is on the left. The EM is on the right in high as well. Maybe I should make a small batch of these multi function modules for EM owners
ARC mania
ARC mania
