Looking for 12 volt Xenon Bulb's
gav6280
10 Min from NDAC.
I am trying to find a supplier of push fit 12v Xenon Bulb's for mt Peli 8C light, without having to spend a fortune.
It would also be nice if it could have a little upgrade from its current 13 watts.
Sorry didn make that to clear did i?
With that link i was supposed to say that type of actual bulb not including all the reflector etc.
I want to see if i can do an incan upgrade for this: http://www.peli.com/?q=en/lights/submersible-incandescent-diving+lights-nemo-4300.html
It currently has a 13 watt 12v xenon bulb but I wanted to know if i could get an easy upgrade for it, as like using it... maybe a 20W krypton bulb?
I cant go down the LED road as it is all plastic or rubber, every single component...
I had a look at that website and the stock bulb pack is pretty darn good. Pelican claims 276 lumens for (presumably) the Hi bulb.
By push-in, you mean PR-based. Some people think bi-pin by that term.
Not only can I not find anything better than that, I think I might buy some for myself...
It's odd that it has a 12 V bulb with a power supply of 8 C cells. The normal guideline is 1.2 V per cell, so a 9.6 V bulb would have been more expected.
If you are running on alkaline batteries, then a 1 amp drive current (12 V 13 W = 1 A) is about as much as the batteries can reasonably support.
If you switched the power supply to NiMH rechargeable cells then you could go much higher, and a 9.6 V 2 A bulb would be feasible, if you could find such a thing. But then you might want to worry about damaging heat sensitive components of the lamp.
It's not an easy upgrade you are looking for. This is a post for the incandescent forum perhaps? (Ask a moderator to move it...)
A further note...you could, for instance, consider the Welch-Allyn 01185 bulb in a bi-pin adapter, which would give you a 9.6 V 30 W option. But you would have to drive that from rechargeable NiMH batteries. And with the likely heat output, I'd seriously fear for the plastic parts in the light :eek:
(And the focus would likely be all wrong, so unless you could adapt that it would probably be a non-starter.)
I think the time i have purchased :
Welch-Allyn 01185
Bi pin Adaptor
8 5000mah Nimh C Cell
I could buy a new better light instead....Maybe i will get that hours titanium 1.3 after all.....
