Check out the VersaTi ET10.
Thanks. This is the light I was looking for, but I don't need titanium. It seems to have reliability problem.
http://www.candlepowerforums.com/vb/showthread.php?t=251177
I honestly don't feel like your getting yourself the right light. Why does it need to be AAA? So you can attach it to a headband or cap or something? Also why aren't you using your zebralight for this? Seems like it would be ideal for your current needs. Maybe I am missing something or we need more info.
Another idea, maybe you just need to use some tape or a chapstick cap to diffuse your maratac.
As said the Peak Eiger is supposed to be a perfect beam. They also offer narrow, medium or wide beam. While not a "budget light" (Eigers start at $39.95 for aluminum HAIII) they do fill your requirements for AAA and flood!~
I have a medium and wide Eiger in the works. I'll post when they arrive.
I believe Peak is now also using an optic for their wide beam option. Peak makes a nice light and is very durable.
The Peak should be about $39 if it is in the US (depending on material chosen).
I think special orders are now being much longer than in the past though.
Don't dismiss the Peak lights that quickly - the Al HAIII is lightweight.What I need is something as small and as light as the Maratac AAA I have but with a floodier beam for hand-free, up-close tasks. The Maratac works fine in this role, but I have to aim the light precisely at the work I am doing. A floodier beam would work better.
The E01 is not bright enough. I had one and returned it.
The Peak lights appear to be longer and heavier than the Maratac AAA.
HJK's review doesn't have the light I am looking for.
Thanks for suggestions, guys.
