Okay, long time reader, first time poster.
I currently have a Proton Pro, for the simple fact that as a military guy, I want something that is flexible enough for the uses I need (blinding white light when needed, variable output including strobe for signaling, and red LED for night use), in a small form factor. However, I find myself wanting (let's face it, it's want, not need ) an EDC flashlights for more specific needs.
I'm looking for the collective wisdom of Flashaholics Anonymous (aka CFP) for this flashlight.
The requirements:
1) battery types to consider = AA, 2x AA, CR123, 2x CR123. AAs for practicality and ease of obtaining spares, CR123s for brighter output.
2) other battery types considered (18500, etc.) as long as it makes sense.
3) must have tactical bezel (aka scallop/strike/crenelated) because of requirement 4 (I will consider non scalloped suggestions, but they MUST meet requirement 4).
4) must be easily used as EDC, but be long enough to be used in a trained defensive manner (escrima :devil:, which means joint locks, pressure points, strikes to sensitive areas). I have a medium sized hand (palm is 3.5" across, so usable length for self defense is approximately 4.25" or longer), and I must be able to operate the light and use it in a defensive manner as needed.
5) variable output is desired. At the minimum, very bright High (Cree Q5 or better), and a usable Low (prefer a 3 output if possible). Strobe is not necessary, but if it has it, fine. Runtimes are considered (the longer the runtime on brightest setting, the better, but it must meet the other requirements). Instant on bright a MUST.
6) mechanism for changing output is irrelevant, but I would prefer strictly one handed operation if possible (see requirement 4).
7) pocket or holster carry is acceptable, clip is optional.
8) forward clicky preferred (but not mandatory).
9) good throw with good spill. I would rank good throw slightly above good spill.
the lower the price, the better (I have to answer to command entity WIFECOM), but if the light meets all the requirements, I will pay what I need to, and sleep with my new light on the couch.
I've looked at the Fenix TK10, the SF E2DL and 6PLD, the Nitecore Extreme and Defender, and the new LF5XT, but I'm sure there are other models out there.
Thanks in advance for the suggestions.
The requirements:
