Looking for single-123 light for using up batteries
Vermonter73
Hi
I'm looking for a single-123 light for using up my old batteries. It'll probably need to be unregulated so that it can run them all the way down. Cree or Seoul. Small as possible. Cheap. Doesn't need to be super bright, I'd prefer it to have decent runtime.
Thanks
Novatac 85P will take the batteries down pretty low. It's programmed to drain every bit of power and to drop in brightness as it needs to to accomplish this task. Meant to sacrifice the battery to save your life if necessary.
Ken
If you are partial to Surefire at all, take a look at the E1L or the L1, both potentially long runtime lights (the L1 depending upon using the low setting).
Anything cheap from DX with a Cree or Seoul that will run the batteries all the way down?
