Looking to add led fog lamps to my 2015 Sonata
Csmith
For whatever reason Hyundai decided that here in the US we don't need fog lights.
I live right by a river and we get a ton of fog here. Thankfully there is still a spot to mount a fog light.
I'm looking for a bumper cut and mount style fog light pod that will actually have a usable fog light pattern. None of that spot or flood light stuff.
Doesn't have to be projector based but that is preferable.
Anyone recommend a product?
They're pretty much right about that. Fog lamps are basically useless.
Fog lamps are still basically useless except to slightly increase the visibility of the road edge so you can crawl along in bad weather at severely reduced speeds.
Unless you use official Hyundai parts, you're going to have to figure out some/all of the mounting details on your own. If you're going to the trouble and expense, carefully avoid the large amount of garbage on the market. These are an excellent, high-end, selective yellow LED projector fog lamp with a built-in aiming adjuster.
