? Low current multi mode driver
outer limits
I am after a low current multi mode driver. Max about 350mA, min about 35mA I am currently using a buckpuck 3023 but is there anything cheaper.
What batteries are you planning to use?
And where did you get the buckpuck from?
:poof:
Robert M.
You can buy one of the following & remove two of the AMC7135 regulators to give you arounf 300ma - 350ma on high.
2 mode
5 mode
I'm not sure what the lower levels would be with any regulators removed. There's other from KD & DX that you can do the same too if your into all those modes. I have the two mode one & it works great, it has memory (remembers last level used).
You could also use a 10.5mm flupic. The regulator is rated for 400ma.
I can also offer you a standard size Flupic with the Draco UI & remove one regulator to give you the rated 400ma. Basically the same as the 10.5mm Flupic but in a 0.55" size.
:poof:
Robert M.
BuckPucks can be purchased from LED Supply
