Robocop
Mammoth Killer
I am testing out a new light made by Peak and it is designed for multiple battery combinations. It workd best on two R123 cells and I have several of these for testing. Some of my samples are protected and some are not.
I believe the light has a 2V cutoff built in however it starts to flicker rapidly as a warning on low battery right around 2.3V. My question is that if this light is designed to use rechargeables surely it must be used only with the protected versions correct? If I have 2 of the R123 cells inside the light and run it until it flickers how bad will this kill these cells at 2.3V total ?
I searched and found many threads warning against low voltage use of unprotected cells however never found any concrete numbers as to just how low or just how fast it will kill the cells? If I do discharge 2 cells down to a total of 2.3V will it instantly kill the battery or is it a long term process?
I am curious as I am testing this light and know many use the unprotected versions of cells. I know there is little difference in cost of protected and non-protected however I do need to have all the info I can in order to give any suggestions to the maker of this test unit.....thanks for the help.
