StrayLight
I have been a proud owner and user of a LS27 for some time, but mine just recently started exhibiting some strange behavior that defies logic: the emitters now operate in reverse order. The low setting now engages the Cree only and high then also engages the Nichia ring. This is the case with a PD Pak, C Pak, and Cx2 Pak (powered by 17670, my preferred setup).
In the interest of full disclosure, the LS27 head had been modded to increase the output level of the Cree emitter, but changing that sense resistor was the only work done on it. I had been using it daily for several months with no problems, and though it has endured some minor bumps on the job there was no impact or other event to coincide with the onset of this reversed output problem.
Help?
Help?
