wojtek_pl
Hi,
I just got MRV Digital from Batteryjunction.com . Great throw !!
But I found serious design flaw (again)... The tail is too long and switch assembly (which is inside the tail) does not contact battery tube. It's 0,4 mm gap. So it worked only when not screwed down properly - and it arrived like that.
This size is too big:
And this is too small:
That leaves a gap and there is no contact...
And how much brighter MRV Q2 (220 lumens) should be than a Novatac 120 P (120 Lumens) ? Because it is not much brighter. And it's not even getting hot.
Could someone check current draw from 18650 on Max ? It's only 0,56 A... How this turns into declared 1.1 A on the LED ? I don't know. But I suspect that 220 lumens will be achieved only from 2xRCR123 power source. I seriously recommend M65 extender. This will provide both brightness and runtime.
Some beamshots comparison. F2.7, exposure from 1/100 to 1/1600, 1.4 meters from the wall.
Something like this http://www.dealextreme.com/details.dx/sku.1340 on the left, MRV Digital on the right, both powered by 18650:
Novatac 120P (RCR123) on the left and MRV Digital (18650) on the right:
The switch is .. not good. When you hit MRV on the side with your hand (gently) it blinks, even it turns on. Sometimes I click and it does not turn off...
Can I have another switch please, not a forward clicky this time ?
For a $120 flashlight I was expecting more... More light and more quality... The very first M1 I got was very good. Now I'm not very happy...
Oh, and it does not stand on it's tail... And it's definitely not a flashlight for white-wall-hunters...
At least with SMO reflector...
