PeteBroccolo
I torture-tested my Pila GL3 awhile ago, destroying my Pila 200 lumens lamp assembly and my Pila LED tail-cap, although the lens survived intact and the body has only minor cosmetic damage. I had bought a Wolf-Eyes 9TX Raider true-clicky tail-cap switch sometime ago, and it had worked on the GL3 just fine before the torture test.
With all the hoopla about Lumens Factory, I decided to get a D26 EO-9 lamp assembly to put in my Pila GL3. Well, it came the other day, so I installed it, removing the larger outer spring first, popped in 2 Li-Ion 18500 1500 mAh 3.7 v cells, connected the true-clicky switch and...NOTHING!
As I started to remove the tail-cap switch, the light came on JUST before I twisted the tail-cap past the last thread. Light output is EXTREMELY impressive, but this is ridiculous! What am I doing wrong? HELP! There are SO many "clients" out there that just NEED to be "enlightened" by me!
