Hi guys,
Well bummer! As of this typing, there are now two reported cases out of about 130 lights where the Nichia ring became non functional after a short period of time. I have not seen these lights yet but I suspect that the BBM converter has died.
The BBM converter is a new design but it is based on a tried and true circuit, the Bad Boy. The LunaSol 27 program was held up for a while due to some problems and issues with this converter. There were some errors in assembly of the converters and the boards were re run a couple of times.
There was an unusually high rate of DOA converters and this was ultimately determined to be due to an inductor used which turned out to be out of compliance, in many cases. A new inductor was procured and the converters were reworked with the inductors being replaced. Because the assembly of the mother/daughter combinations of converters is so time consuming, I tested 100% of both mother and daughter on the bench prior to assembly because it is not uncommon to have a small percentage of DOA converters. I built the lights with converters which tested out properly in function and tested the assembly at a number of steps moving towards completion. All of the lights were shipped in proper working order.
Now there are two suspected cases of BBM's which have failed shortly after use. Suspected only because I have yet to confirm the problem on the bench. I have informed both parties that I will take the lights back for full refund or replace the converters if that is in fact what is required.
After receiving the first report of a problem, I was bummed and told myself that if there were a second report sounding like the same problem that I would place an alert here on the forum to advise you guys of the situation.
I want to alert you to this for a number of reasons. First and foremost, it seems to simply be the right thing to do. Second, some of you may not use the lights if they are intended for the shelf and I would ask that you do use them so if you should have one with a "compromised" BBM, we can identify it now and get the situation corrected.
Wayne has tested the circuit extensively at this point and it is a sound and solid design and any problems would be an exception and not the rule. For my peace of mind as well as yours, I would like to identify any of these exceptions and get them removed from the population as soon as possible. It would be just like Murphy if the two now reported was the full extent of this and it turned out this advisory served no further purpose.
Although I offer no written or implied warranty on these "experimental" and limited offerings, I will stand behind them to the best of my ability. I wish I understood the failure mechanism here but these wonderful solid state drivers and circuits are simply beyond my ken.
It is not uncommon to have DOA converters but the infant mortality in a few of these BBM's is a new experience for me. The demand of the 6 Nichias being driven at 18 mA in series is not a big demand on this circuit and it is well below its capacity in driving the LED's as I understand it. I have complete confidence in the driver and this is supported by many months of using some with no issue whatsoever. For what ever reason, it seems that a couple bunk units got out the gate undetected and I hope that we can identify those ASAP and remove them. Of significance and comfort to me is the consideration that those converters which have failed have done so very quickly if not immediately (which would be the ideal case, if there is to be a failure)
Well sorry guys and although I have nothing but confidence in these lights, should this alert cause any of you undue concern regarding your lights, I will be happy to take the lights back for full refund.
I may be premature in posting this alert and causing some undue concern but I want to nip this in the bud so we can move forward. If there are some bad bad boy mothers out there, let's round them up and get rid of them.
