yaesumofo
Lunasol Lottery.
OK I know it is a small sample but with 4 (2 ea) lunasol's here are my observations regarding the Emitter lottery as it pertains to the Lunasol.
OK The two Lunasol 20 which I have the Low beam Nichia emitters are for all reasonable purposes the beams are exactly the same.
The Lunasol 20 High beam are so extremely close that to my eye there is just a slight difference between them tint wise brightness on the two lights is pretty much the same. When I get some new batteries I will run the lights for 5 minutes and measure them for output with my meterman 631. Until then any observations regarding the power levels from your Lunawolf are welcome here AFAIAK.
The Lunasol 27 was a little different.
On low again the beams are virtually identical. When the high beam is engaged there is slightly more difference between the lights. With one being a little warmer than the other. The Brightness of these two lights is very close, again I will measure them and post the results here when I get some more batteries.
Overall between the 2 pairs of lights there is more difference between the Lunasol 27 lights with the Lunasol 20's being very close to being the same.
I suspect a larger sample set would yield a wider variety of tints and brightness levels.
BTW I was able to measure the color temperature of one of each of these today (the pair I take to work) and here are the results.
The Lunasol 20 on low measured 10,000 degrees K
On high it measured 8,500 degrees K.
The Lunasol 27 Low beam measured 5,900 degrees K.
and the High beam measured 6,500 degrees K.
I is clear that the Lunasol 27 is a whole lot closer to daylight than the Lunasol 20.
That 5,900k is a pretty impressive number IMHO. The Nichia emitters do a good job of producing daylight colored light. I suspect that these will be used in more and more light panels used for motion picture still and general "digital" image capture.
Anyway that is all I have.
Yaesumofo
Yaesumofo
