IMALENT LD10 small led flashlight
imalent
Shenzhen
IMALENT LD10
www.imalentstore.com
IMALENT LD10 rechargeable flashlight is a small led flashlight with a maximum of 1200 lumens. The lighting distance can reach 247m.
Small size, light weight and high beam intensity. Night and outdoor activities, walking,Best choice for mountain climbing, camping or work
The 6 settings of
IMALENT LD10 mini flashlights replace the need for multiple flashlights: (10lm / 150lm / 500lm / 800lm / 1200lm / strobe light).
OLED display: The digital screen of the bright flashlight will show its charge, and then we know clearly that the battery charge is still there.
Special design: LD10 LED flashlight, made of high-performance aluminum alloy. It is durable and almost indestructible.
Product features​
· Utilizes 1 piece CREE XPL HI LED,with a lifespan up to 50000 hours,and
a maximum output up to 1200lumens
·Built-in multi-functional OLED display, which can show various parameters
and settings
·USB magnetically charging function make it easy to get power.
·Product size: 72(length)*22.5 (diameter) mm
· Net Weight:57g(battery included)
· High efficiency constant current circuit will maintain constant brightness
· Built- in thermal control module will automatically adjust the brightness
output,keep using comfortably.
· Combination of toughened ultra-clear mineral and anti-reflective coating
glass
· Aluminum OP reflector
· Aerospace-grade aluminum alloy body, wear-resistant type III hard-anodized
surface treatment.
· IPX-8 standard waterproof(Under water 2meters)
· Impact resistant(1.5meters)
It looks like a nice flashlight, but will extra charging cables/charging adapters be available to buy so the flashlight won't be useless in case your cable breaks or gets lost?
