Re: Lux measured: Infinity Ultra, Arc-AAA, Dorcy 1
Cougar, way to go! That's some good testing you're doing. /ubbthreads/images/graemlins/thumbsup.gif
There are a couple benefits to regulation that we don't talk about enough. First, it can protect the LED from overdriving! For example, the regulation circuit in MR-X guarantees that the X3T emitter will get a
maximum of 1.5A current draw, which is already quite high! /ubbthreads/images/graemlins/mad.gif The emitter is extremely well heatsinked and probably handles the overdriving in this case pretty well. But without the regulator in place, fresh cells might pump much MORE current through the X3T and cause bad things to happen to it! /ubbthreads/images/graemlins/ooo.gif So a regulator in that sense acts like a sort of specialized surge protector.
Another benefit to the regulator is that it keeps the cells from spewing out all their energy in the beginning of runtime, when it would only be wasted as heat (or worse!), and essentially saves the excess energy for use later, when it's needed! Think of this in terms of horse racing. If the horse starts the race at top speed, he'll usually run out of energy and be soundly beaten by the end. Instead, the jockey holds the horse back a little at first, then entices him to empty the tank, so to speak, in the final turn. This way the horse uses his limited energy much more effectively. And so it is with a regulated flashlight! /ubbthreads/images/graemlins/grin.gif
Regarding your measurements of current and voltage by removing the tailcap: strictly speaking, it's inaccurate to measure voltage this way. The rule of thumb is voltage ACROSS, current THROUGH. You hookup the way I described for current because the DMM needs to be "in the loop" of the circuit to measure the current running THROUGH it. However, voltage needs to be measured not in series with the circuit, but rather in parallel with it. That would mean somehow touching the DMM probes to the positive and negative terminals of the battery WHILE the light was running normally! Such as with the tailcap on. This, of course, is pretty difficult to do... you'd probably need to make some temporary connections with wires to get access to everything for that test. If you have the ambition, go for it! If not, the "loaded" current (current while running) and "unloaded" voltage (battery's voltage when pulled out of the light) will still give at least a partial picture of what's happening.
Regarding photocells, the CdS ones (cadmium sulfide) are available cheaply from Radio Shack. ($1-2.) CdS photocells are like the ones used in the "electronic eyes" used on nightlights to turn themselves on at dusk, for example. They're the little round things with the zigzag wire pattern visible across the surface. If memory serves, you'd measure the resistance of the photocell, which would change depending on how much light hit it! Easy to test, though note that response isn't necessarily linear. (In other words, half the resistance doesn't necessarily mean double the light!) They'd be good for doing some sort of brightness over time runtime plot.
Ready for me to spend some more of your money? /ubbthreads/images/graemlins/wink.gif
Take a look
at this thread I did a while ago, which reviews a neat power supply available from MPJA.com (a surplus electronics warehouse) for $60. This particular PSU is nice in that you can adjust both voltage AND current! Perfect for flashlight experimentation. I would also suggest a pair of banana jack test leads available from Radio Shack for a few dollars, as they plug into the terminals on this PSU easily. I think I mention the RS part number for those toward the bottom of that PSU thread. Highly recommended! /ubbthreads/images/graemlins/grin.gif
As far as where to post, sometimes you're just not sure. It's more important to post in exactly ONE place than to get the place exactly right. Personally, if what I'm doing involves electronic components, I usually put it in the electronics section, and if it involves putting together some custom light or experimenting with a light-generating circuit, I put it in the mods section.
/ubbthreads/images/graemlins/icon3.gif
Sorry I keep dropping these long posts on you! /ubbthreads/images/graemlins/icon15.gif
Yes, there's lots to learn about flashlights, especially the ones that are no longer just a bulb and a battery. Lots of subtleties. As far as knives... well, I'm afraid I don't really understand how you could spend all kinds of time reviewing one of THOSE. /ubbthreads/images/graemlins/icon15.gif I'm sure it's just a reflection of my own ignorance on those matters! Maybe you could teach me... sort of a knowledge trade, you learning flashlights, me learning knives? /ubbthreads/images/graemlins/thinking.gif
Not sure I've even got a single genuinely good knife in the house. What I'd love to find would be a pocket knife that's both "good" by
your standards and affordable! The affordability test is that I shouldn't be losing sleep at night worrying about the economic impact of losing the thing...
/ubbthreads/images/graemlins/sleepy.gif
