I've decided to upgrade my original-spec Raw NS (2006 vintage) which is currently running a Luxeon III (TWAJ bin) off a 250mAH lithium ion rechargeable. By my (unscientific) eye, it's probably making 40-50 lumens.
I'm pretty sure that the light is more-or-less direct drive on high, although it might have a 1 ohm SMD resistor in place, I can't swear to it. The reflector, for what it's worth, is a MCR16.
The two options I've seen for this mod are the SSC P4 and the Luxeon K2 (nobody seems to have upgraded a non-cree RawNS with a cree, so maybe this would require more than just an emitter swap?) so I'd love some help picking between:
SSC P4 U3SVNH
Lux K2 TTFC UW0E
I'm not entirely sure what the pros/cons of each one are, but ideally I'd like to keep things simple and get the most out-the-front lumens. I did try reading the datasheets, but it seems like Seoul and Luxeon are rating their LEDs at different current levels?
SSC P4 U3SVNH
Lux K2 TTFC UW0E
