hello,
can anyone explain to me wich and how is the easiest way to atempt rebel led on a star
thanks
George do you mean you're just using a heatgun?....If so, then solder paste and a hot air tool works great. After doing more than 100 that way, it really is very easy to do.
What kind of solder past are you using?
I see you used a 2005 penny for your close-up.
Pre-1983 pennies are copper, '83 & after are 98% zinc. Zinc is not a good heat sink. If you did at least one with a pre-83 penny, it'd be interesting to see if the Rebel on that one stayed cooler.
Hot air tool - not heatgun :)
You need to be able to set the temperature and airflow of the heated air. I have used a good priced and decent performing all in one hot air tool:
http://www.circuitspecialists.com/prod.itml/icOid/8010
for the past couple of years. Used one at work too. Has been reliable and good bang for the buck.
Handy for heatshrink tubing to removing/replacing faulty IC's etc.
I just bought solder paste online (after some searching) at http://www.zeph.com/ there's a lot of interesting info on there and some videos of various soldering procedures. I just bought the solder paste there and a few tips to 'experiment' with.
For soldering the Rebel, the solderpaste and the hot air tool work VERY nicely. I run around 320C on the tool and just warm everything up and then concentrate the air stream around the edges of the Rebel. You can see the solderpaste start to melt, then go fully liquid and the Rebel floats/centers itself perfectly onto the pads (surface tension).
The solderpaste has the flux in with it - so all you need is a few dabs of solderpaste, tweezers to 'stick' the rebel down on the paste and then heat up with the hot air tool.
Of course being in Europe, you would need to source the solderpaste locally and due to your loony EU stuff it would likely have to be lead free too :)
cheers,
george.
cheers,
george.
George,
What kind of solderpaste from zeph.com can you recommend for use with the hot air gun in your link?
I don't think so... :)Originally Posted by georges80
Do they still sell lead based solder in the EU?
