Mirage_Man
I don't know if I'm alone but sometimes I find it a real PITA to get a M@G switch centered back in the body once it's been removed. I came up with this simple but totally effective jig. I took a piece of Delrin drilled and reamed a hole through it that matched the O.D. of the switch shaft. Then turned a small diameter that just fits the hole in the M@G body that has a length that's the same as the depth to the surface of the switch from the outside of the body. The larger diameter doesn't really matter as it's just to hold on to.
Once the switch is in the body you just line up the switch as best you can then press in the jig and it will perfectly center the switch. Slip your allen wrench through the jig and body, tighten the screw and pretso perfectly centered switch. :D
I haven't made one for a D M@G yet but it should work the same. Here's the C jig I just made.
