M*g11 M*g85 on 2 or 3 li-ion?
Lumencraft (Matt)
Vendor
Missouri
I was wandering if anyone is currently running a m*g11 on 2 li-ions? I have a m*g74 (7.2v bulb) that I have tested at 8.4v so I orederd 2 D cell li-ions for it. But I am a little conserned that wa1111 being 6v may:poof: because of the over voltage from fully charged li-ions.
Aslo same question for m*g85 does anyone have one running on 3li-ion direct drive? If not will a 12v resistor be enough. If you have this setup feel free to add pics. or any instructions you think may be helpful.
Thanks in advance.
I am running a Mag85 off of 3 AW 17670 3.7v Cells.....I call it a "Mini Mag85"...It is a 1D size mag...
Li-ion batteries, although they show ~4.2V when fresh off the charger and on an open circuit, don't actually function at this voltage. When you put a load on them, they will (as with almost all batteries) sag in voltage from the load. Depending on how much they are stressed, this may be down to ~3.6-3.7V, so the bulb will never actually see the full 8.4V of two li-ion cells.
Running the WA1111 will mean you're just driving the bulb to ~7.2V, which it should handle fine. Running the m*g74 means you are driving it at speck, and not pushing it at all probably. A 1185 should be able to take 3 li-ions as well, the only thing you have to watch out for is to not pop in the cells hot off the charger and let them rest for at least a few hours beforehand.
I run a Mag85 off of 3 AW C Li-ions, and a FiveMega Mag11 off of 2 of AW's C Li-ions. Never flashed a bulb on either, even hot off the charger. :thumbsup:
Better = 2x li-ion + Philips 5761 bulb = brighter than a m@g85 with 3x li-ion.
Northern Lights did do a lot of research about this setup. Here's a Northern Lights quote:
5761 Vbat=7.2 Vbulb=7.04 bulb lumens=1336 torch lumens=854
The 5761 needs 'C' Li-Ions to power it - it draws 5.5A, which is too much for 18650s and far too much for 17670s.
The 5761 and WA 1185 are very similar in output. The 1185 is a more efficient bulb, IMO.
Wow good solid info you guys. I think since I have 2D cell li-ions on the way I may look into that 5761 bulb as well. I realy appriciate the help and the new (to me) Ideas about other bulbs and sutch.
One more question. I followed some of the links provided for research and found this link. http://www.light-edge.com/
but it doesnt seem to be working, I was wandering if this is still in business? The quote I saw said there were several good parts for m*g mod there, like reflector, always looking for another reflector source:D
I have had problems running my Mag-85 on 3 of Emillion's original unprotected Li-ion D-cells. The extra capacity of the D-cells seems to result in a higher operating voltage as opposed to 3 of AW's protected Li-ion C-cells, which many CPF members have reported to work OK. On the one bulb that survived for awhile, the output was incredible, but it failed quickly, as did a couple of subsequent victims. I now have my Mag-85 running on 9 Eneloop AA's, and it works quite well, although it is not as bright as the original 1185 on the 3 D-cells.
George
In addition to my Mini Mag85 running 3 of AW's 17670's, I am also running one with 3 of AW's "C" li-ion cells. I have never had a problem flashing a bulb with either of these setups...even hot off the charger...as far as I am aware Li-ion cells hold their charge unlike the NiMH cells which dont retain their charge over time...
As I said in another post....I have many of the high powered incans and the Mag85 continues to be one of my favorite light!!!
I'm sure that YMMV, but my FM85 had an instaflash on batteries that were charged to 4.200V, and then rested for three (3) DAYS. When I got to a place where I could check their voltage a few days later they clocked in @ 4.185 +/- 0.002V.
Damn good cells, those AW's: they lost ~0.02V after 7 days. I did check them off the charger (BC-6) and they all clocked in at 4.200 +/- a few hundreths.
So, given this experience, I'll only be charging the Li-Ions from AW to 4.000V in the future. It should prolong the life of the cell, as well as keep the bulb healthy beyond a $5.00, 1 second flash...
As everyone has already said well, but I'll add a couple of minor tips.
Chongker - Absolutely right about voltage dropping under load. To see the capability of a particular brand/size you need to find a run-time plot test where a cell is discharged at a particular Amp rate. An example of this is the curve from AW's C Protected Li-Ion that he sent me (i.e. green line shows how well the voltage holds up at 4.5 Amps draw rate)
However, Li-Ion cells should not drop voltage by waiting "hot off the charger" as you see with NiMH. If you are seeing a drop, either your charger is ending the cycle prematurely, or your cells are aging (Li-Ion start losing capacity several years after manufactured), or have been damaged.
One of the most important issues to remind everyone about when looking at a particular battery/voltage setup is the amount of resistance that is in your setup. A stock Maglite using FiveMega battery holder, gold bipin bulb holder can have a lot of added resistance that effectively blunts the voltage delivered to the bulb.
So one setup that Choppers uses with 3 x Li-Ions can have high resistance (protecting the bulb from flashing--but with side effect of lowering the potential overdrive brightness); while some other 3 x Li-Ion setup can have lower resistance and flash the very same same bulb.
I have orderd a 2D protected li-ion pack from kd that I am going to do some testing with. This week already I have flashed 2 bulbs that by ALL rights should NOT have flashed. The one I flashed this evening was wa1185 running on 3x 3aa to D converters (the electrolumen ones) after the batteries reseted for at least 6 hours. What was realy wierd was it was not an insta poof. The light ran for a couple of miunutes befor it blew. I think maybe I bought cheap batteries and they are the trouble. I have Kodak 2500mah digital camera batteries and thats the second bulb I have lost useing them in a configuration that mathmaticaly should have been fine.
Also I was still wandering if this link is just broke of if this company is out of business? http://www.light-edge.com/
I run a M@G85 with 3 AW"C" cells and all the resistance fixes I could perform with no problems at all. I prefer to use Litho's potted lamps as opposed to the bi-pin lamps. I like that stability of the potted lamp and the ease of field replacement. I have never had a problem with insta-flashes...(I did have a lamp explode on me once when it was installed without cleaning it though).
Ronnie @ light-edge.com and I collaborated on purchasing reflectors a few years ago. Due to personal things, he has dropped out of circulation.
You're right about your setup:
- (3) Electrolumens holders (more resistance)
- rested cells (6 hours)
- Kodak 2500 cells (a fair amount of voltage sag)
I doubt these things contributed to your blown bulbs.
Ditto on what EvilPaul2112 said... ...(I did have a lamp explode on me once when it was installed without cleaning it though).
If the bulb is running a minute or two before it fails, I would suspect that the bulb wasn't cleaned properly. Any oils from your fingers will collect heat and cause a real short life for your bulb.
My rule of thumb is "Whenever the head comes off, the bulb gets wiped before the head goes back on." I adhere to this rule whether or not I touched the bulb.
I think I should start cleaning my bulbs with alcohol... I just burned 1185 that I installed yesterday. I don't think it was instaflash, it burned for few seconds before failing after I installed fresh c-lions from charger. I had maybe 10 minutes on that bulb...
