M4 + KL6
ianb
Herts, England
If I were to use this combination what sort of runtime should I see?
I assume the same output as the KL6 is regulated.
I love my L6 and have a M4 on order and was wondering for longer use(of the L6) if I could put the KL6 on the M4?
thanks, Ian /ubbthreads/images/graemlins/smile.gif
Yep, the KL6 works fantascally on the M4. You should see an extra 30 minutes runtime(roughly), coupled with a brighter, longer lasting moonmode.
And the fact that this combo thrives on 2 Pila 168s is the icing on the cake.
Ian,
I have a KL6 on M4 and I really like the look and balance of the light! Certainly the run time is extended but I don't do run times so I don't know what it is. /ubbthreads/images/graemlins/icon3.gif
Well I look forward to getting the M4 then, then I can get some definate runtimes,
I would like to try Pila's but at the mo have 100 odd 123's so a while before I need anything else,
kj,
With a Lux III replacing the 5W, do you have any fel for run time? 3 hours maybe?
Do you use the stock circuit with 3x123? I have no experience with that configuration, but I also guess it will run 3 hours or so in regulation. I assumed the power consumption of the Lux III would be about half of the 5W and the efficiency of the converter would not change so much.
Anybody know when the KL6 will be available in the states? I'd like to get one as an option to my new MG Guardian.
Thks.
Al, thanks for the Photos, the M4 looks great with the KL6 on,
