Mag reflectors
Lolaralph
Pennsylvania, USA
I've done two mag mods, one 5 amp SST50, one 2.8 amp SSC P7, both are using cut stock reflectors. I've sputtered the P7 reflector, but have noticed a significant reduction in briteness,this reflector also improves the beam quality of the SST50 as well. My question is, how much better would a britelumens reflector be vs. the sputtered one, and would his smooth one be an improvement as well, thanks for the opinions
The SMO BL reflector will give the same effect that the stock mag reflector does. Now if you do go with a LOP BL reflector that will improve a lot over the sputtered one. Usually sputtering has the turn out that you experience, its hard to get it perfect.
