I built a Mag85 a few weeks ago, I have a FM 9aa holder Powered with enelopes in a 3d body with a prc to bi pin brass adapter and of course a non stock reflector and window.
It is bright but I don't think I'm getting more than 700-800 lumens with a fresh charge based on comparisons with my TK40 which should appear less bright but starts out about even and goes downhill from there. I expect this may be due to me using a stock switch, or possibly my battery choice.
It's possible that part of the problem is that my batteries were going through their first conditioning cycles and with use it might well get better, same with the old switch that hasn't been used much and might be tarnished inside a bit (I pumped it a few hundred times hoping it would help).
I'd much rather maximize conductivity so that I could get 1200ish lumens to start and still get 800-900 as it settles down for the long haul.
Also I was wondering if I just kept stock parts and disassembled all contact points and coated it with progold or deoxit ( same stuff I hear) would I notice a perceivable difference in max brightness, or do I need to upgrade some more components?
I'm happy with the light. I use it as needed all week and recharge it on the weekends and although it is dimmer at the end of the week it is still effectively bright, much brighter than a stock mag. This because I conserve the on-time as much as possible, and mostly require only short bursts.
I believe I'm getting more than 30 minutes effective time possibly due to the resistance problem not drawing as much current(Silver lining). And 30 minutes must be a long time since I use the light all week without it going dim.
Any suggestions?
EDIT: Just to clarify what I'm looking for is a list of ways to decrease internal resistance with original parts and/or with other parts. I can live with what I have but over time I want to make this more top shelf.
Any suggestions?
