I have read sometime ago that someone have had the same problem and the key was in batteries... (1 bad cell)
however I have the same problem at the moment becouse I have never run my mag85 for long burns but yesterday I did and after that the mag switch cover was hard to push and than I tried to move the cover and I heard: pssssssssss :candle:
well, I think my batteries ar OK becouse of I checked them all...
I can suppose that this happend becouse of the heat generated by the bulb...
I have also done a test:
1)I have take my mag85 and I turned it on (with fresh batteries) for 4 minutes...than I've turned off the light and I've moved the S.C....
it vented.
2) I have turned my light on for 4 minutes again, turned off, removed tail cap, moved S.C....
it vented.
3) 4 minutes run, turned off, removed head, moved S.C...
it didn't vent!!
what do you think?
can the heat generated by the bulb expand air and make pressure?
PS: if MODs can find the similar thread, fell free to close this!
it vented.
it vented.
it didn't vent!!
what do you think?
