[ QUOTE ]
CM said:
First, the output cap of the switcher is probably considerably smaller than the output cap of your HP supply. I bet you have at least a couple hundred uF electrolytic in your power supply. Yes, that and the 12V will probably blow a 1W. I don't think the ceramic cap in the BB has the oomph to pop a 1W LED since it's probably no more than 10uF, probably more like 1uF due to the switching frequency of the regulator.
Second, switchers are a different beast than linear supplies in that their transient response is considerably faster. This one has a response time on the order of tens of microseconds (due in part to smaller inductors and caps from the 1MHz+ switching frequency). This is probably enough to prevent the LED from being destroyed. We've routinely seen these LED's overdriven well in excess of an amp so I think that statement has some element of truth to it.
Finally, that's my story and I'm sticking to it /ubbthreads/images/graemlins/grin.gif
CM
[/ QUOTE ]
Well, it was just a 'warning'. Give it a go on some Luxeons and see what happens - if they survive, no harm done...
I assumed it was a stopgap measure - to save buying a powersupply with current limit /ubbthreads/images/graemlins/tongue.gif
Driving them at over 1A means nothing - it's the transient high voltage (and we're only talked 12V) that will destroy the LED.
I'll happily let you do the 'test' with your Luxeons /ubbthreads/images/graemlins/grin.gif I don't plan to destroy any more of mine...
Note, the HP supply has current limit on the output - so it will not provide a huge current pulse from the output electrolytics - it will current limit. Again, the damage is done by the high voltage transient.
I'll have to hook up my current probe to my scope and do a transient test to see what the HP supply's output looks like when the load is first applied (I'll use a load resistor...).
george.
