Z
z_rmbassett21
Guest
I have a MagicShine battery and understand that the PCM allows the pack to drop down to 2.0V before cutting off. From what I have read, this is too low and I should have something more on the order of 3.5 V. I am thinking of replacing the PCM with
http://cgi.ebay.com/Protection-Circu...item335f518d08
I have also thought about replacing it with this board:
http://www.all-battery.com/pcbfor74v...865032056.aspx
Would the following be the correct wiring and would it work with the above board.
http://mysite.verizon.net/resxqr4f/Document1.bmp
This looks like there is a connect at the +/- terminal for all four cells?????
Finally, what is the difference between the COM and BM pads?
Thanks
Rich
Thanks
Rich
