tibim
Anyone have any experience with maglites in cold weather(Mine is a 3D)? I keep mine in my vehicle and the other day I went to go use it... it was probably about 20F outside. It worked fine at first and then shut off.. When I went to cycle the power and turn it back on the switch was making it light up when it was halfway pressed, but as soon as it "clicked" on it would go back off. Now that it's inside my house and warm it works just fine.
I'm running a terralux led conversion in it(seoul) and I'm not sure if that is causing the problems or if it's the switch. The fact that it would turn on when playing with the switch and pushing it halfway down makes me think it's a switch issue.
I'm going to put the magled dropin back in and see if it makes any difference.
-tibim
-tibim
