Maglite threads
07accordEX
CA
Hey does anyone know what size the threads are for the head and tailcap?
Thanks
D size, so say I ask someone to rethread it, what do I ask for exactly?
I ask because I know someone who has access to lots and lots of machining equipment
Just an FYI:
I don't know about AAA or C Maglites, but AA and D are as above (fine thread - 20 threads per inch).
FYI- The AA are 28TPI, several of us measured them here recently. I don't know about the D size but your info is suspect.
Accord- Ask the machinist to measure the threads. They can do it accurately with no guesswork.
It does not help on the D size unit but the AA unit head is a multiple start quad thread with 4 threads per revolution. The thread pitch is therefore a 4x multiple of the basic thread 0.05" pitch size which makes it a 0.2" pitch. Threads like that are interesting to cut. ;)
Check the head threads and see if there are multiple thread starts around the barrel. Measure how much the head advances in one turn also.
I've threaded several C bodies for heads all with a standard 28tpi pitch.
The C & D mag heads are single start threads. I think the reason for the multi start threads in the AA is due to the switch location.
I only had the head measured, but it was done with a thread gauge and that is what it came out as. Maybe they misread the number. :shrug:
They didn't misread the thread gage number they just mis-identified the threads. A quad multi-start thread is kind of hard to miss tho. A double is easier to miss but the thread angle on a quad makes it look very strange. The TPI nomenclature is useless for a multi-start thread. The thread pitch and # of thread starts are how they are identified. I have never personally cut a quad but I have cut a double once.
You are very probably correct! :twothumbs
