mah vs ah
tompen
Maryland
The readings I am seeing on my BC-9009 are in ah amp hours. I am working with 2700mah batteries, how do I convert ah that to mah so that I can understand accumlated capacity after charging?
This is what happens when you are accustomed to English units of measure :)
After all, there are no millifeet, millipounds or milligallons...
There is a milliinch though, except it is called a thou.
milli"X" is 1/1000 of "X". Thus, mAh is 1/1000 of an Ah. You should be able to figure out how to convert 2.51Ah to mAh from that information.
Thanks Gazo and the rest of you, that is what I suspected, that I should just move the decimal point!
