koala
WARNING: Be aware that the charger may not terminate properly, so melted cell & fire is possible.
Method 1:
Right, I am sick of 'crap' cells and I have lots of them. I know they still work fine, despite slightly higher than normal internal resistance. Sanyo claims the cells to be 20-25miliohm. I need to stop the charger from getting "HIGH". So I inserted the cell, set the charge current, all set and Enter. Immediately after pressing the Enter button, I short circuit the cell with a 12" 30awg wire. I think 3 seconds will do, the charger will start the whining and charging takes place. No more "HIGH"
This fools the charger but beware that this may also blow the mosfets. Also, you are shorting the cell. I am not sure if one should do it but it's a solution for me, if I am stranded on a holiday with my cells turning crap out of a sudden.
Method 2:
There is a second safer method but you need to have very quick reflex. You will need a good cell. Firstly insert the good cell, set the charging stuff then hit Enter. After 10seconds or so, yank the good cell out and insert the 'crap' cell. You need to be VERY quick, have the 'crap' cell ready in your other hand. No more "HIGH"
Method 1:
Method 2:
