I posted this a long time ago but I didn't have time to come back and post the results, and tonight I found the old paper where I wrote down these numbers and here is the story:
I took a set of 4 fresh eneloops. I did a few charge/discharge cycles on the MAHA C9000. I labeled them A, B C and D. Then I run a charge 1000 mA / Discharge 500 mA Cycle. After each cycle, I rotated the cell so that each cell was in each slot
so I did
ABDC
BCDA
CDAB
DABC
for each cycle, slot 1 shows a charge capacity of about 1820-1840 mAh, and slots 2 3 and 4 show about 1900-1920 mAh.
When I do a discharge cycle, all 4 slots show about the same capacity, about 1830-1850 mAh
I believe slots 2,3 and 4 work properly, and that slot 1 will discharge a battery properly and show the correct capacity, however, when it charges the cell, it shows about 80-100 mAh LESS than the real charge put into the cell.
The charger is still under warranty, should I bother to get it fixed/replaced?
so I did
ABDC
BCDA
CDAB
DABC
