VanIsleDSM
I'm mostly into fixed lighting, but I have myself a lathe now and I've decided I need to build myself a nice LED torch. I'm going to machine it all out of aluminum.
The thing is.. I don't know anything about flashlights! I've never owned a good one. I think the fanciest light I have is a an old black and decker snake light - So I need some direction, though I have come a decent way so far.. here's my plan:
I've already ordered 3 R2s from Cutter and 3 of these reflectors:
http://www.cutter.com.au/proddetail.php?prod=cut738
I'm going to use 6x18650 in series, and because I couldn't find a suitable driver that I liked for this application I built my own:
There's a couple of them there next to a C battery.. the larger one is the one I made for my flashlight, as it'll fit perfectly at about 1.5" it's also fitted with a copper penny heatsink on the chip.. the other one I just made so I could get it smaller than a C in diameter... It's a buck driver than can run up to 36Vin, for a max of 9 LEDs in series. Adjustable current output up to 1.2amp via a potentiometer, or optional PWM input. If you want to know more about the driver, check out this thread:
http://www.candlepowerforums.com/vb/showthread.php?t=195274
I have a good push button switch too, I want to keep it fairly water tight for all weather conditions, so I think I'm going to glue some rubber over a hole in the side of the body, with the switch underneath.
The only thing is.. I'm somewhat wondering whether I should go with 8x17670 and 5 R2s now.. I think I need to destroy all the P7 lights out there. But then again never having used a good torch.. I'm sure I would be pretty satisfied with what I've got going right now.
So please, fire away some suggestions.. Like I say.. I've never had a good torch before, I need a bit of direction to make sure I don't overlook any obvious flashlight amenities.
