Manafont 6047 alu reflector with xp-g beamshots
Foxx510
Australia
This may be of no use to anyone, but I thought I'd share these in case someone else wants to play with this cheap reflector. It worked out pretty well, beam is tighter than the regina reflector I was using previously. Emitter is sitting .5-1mm from the base of the reflector. Power pole is about 15-20m away. Comparison beam is Akoray K-106
One should NEVER assume that beamshots are of no use to anyone :naughty: Thanks for taking the time doing them and sharing them :thumbsup:
JanCPF is right, a picture is worth a thousand words...
Thanks for the pics, looks like a pretty decent thrower.
Thanks for sharing this, fox. I've been using this P60 reflector a lot in my DIY builds lately. It's a great deal and my favorite beam pattern with the XM-L in the P60 size. I noticed in your post in the P60 thrower thread about this and the Manafont reflector that you said the XP-G's donut was almost undetectable. I may have to assemble myself one of these with a neutral R4. I've got an XP-E coming in to try Orbital's setup for throw. I'll have to make a beamshot comparison with the two.
