Thank you Vinh for your incredibly hard work. Ordered my friend!lovecpf
I just ordered a Mateminco MT90vn Spec C.Spec C supposedly has continuous turbo! Vinh must have added more heat sinking. DriverVNX2 mounts directly to the host so there is PLENTY of heat sinking since the light's mass is obviously massive. The factory driver has a thermal pad like material injected to cool the driver but its still not as ideal.It will replace one of my BLF GT90vns.
Once I receive it, I'll order a second one, perhaps Spec B. Spec B has great value if you are OK with the UI and the limited turbo timer.
Yeah I already felt pretty illegal using the K75 anywhere here in the city, I can't even imagine using that thing. You're literally a helicopter searchlight at that point.
Well, maybe not quite "literally" until you reach 60,000 Lumens in a 4 degree beam. But yes, it's all in fun!
I doubt helicopter search lights are that powerful. I doubt such a light even exist. But if it does, I would love to see it!
SKY, look up the Spectrolab NightSun. These have been around for 25-30 years producing just the numbers I posted. I'll make it easy for you. Here's the datasheet: http://www.spectrolab.com/searchlights/pdfs/SX-16_Enhanced.pdf
My WWII, 60" Carbon Arc produced 800,000,000 CP when new and about 220,000 Lumens.
The Carbon Arc uses a 5 foot Bronze and/or brass, Rhodium plated mirror. It would be almost impossible to find a place that could accommodate plating the large mirror and it would cost a small fortune to buy the Rhodium. None of the owners (many belong to a Google based forum) have ever attempted this that I am aware of. The light is not produced by a bulb. It is produced by striking a 7/16" diameter Carbon composite rod against a 5/8" diameter, Cerium core rod and then drawing them apart to about a 1/2" gap where they burn down to short nubs. The rods are fed with about 150 Amps at about 78 Volts DC. It's very similar to the light produced during arc welding. The Cerium core produces a a higher intensity arc than pure Carbon. I got about 3+ hours on the positive rods and 2.5 hours on the negative rods.
The Mateminco MT90 plus is probably the largest production LED flashlight being produced, with the greatest throw. (If not, I would love to see the ones that are larger, or with more throw).
Even so, it can't really compete against light sources such as helicopter and tank searchlights, which are not meant to be carried by a person. Also, I'm sure it can't compete with the brightest HID and Short Arc portable lights, with tens of millions of Candela.
I would love to see technology improvements that would permit a hand carried LED flashlight to reach portable Short Arc throw levels. LEP flashlights probably would reach those levels first.
